Home > Technical (L322) > TDV8 no power, white/blue smoke
Page 2 of 5 <12345>
rar110
I bought EGR emulators before the EGRs failed. The emulators were less that the cost of a single EGR. Mines running very happily with the EGRs disabled. ______________________________
Post #405063 16th Sep 2016 9:41pm
gsmith1
2007 Range Rover Vogue TDV8 Lucerne Green
Hi rar110,
What/Who's product did you use to decommission the EGRs? How smoothly did it go.
Cheers.
Post #405307 18th Sep 2016 10:20pm
rar110
Gday
It's going well. I was planning to have a look down into the intake manifold after about 5000km to see if the coating of oil and exhaust soot had changed. It certainly didn't looked blocked previously like I've seen on other makes. But it was coated.
It's a plug and play set up. The Anderson like plugs for the EGR are at the top of the motor. The emulators are installed by unplugging the EGR which makes it inactive, and then plugging in the emulator in place of the EGR.
It's sold through a website. Just google Autocode and emulators. ______________________________
Post #405319 19th Sep 2016 12:40am
gsmith1
Thanks rar110, I ordered a set today from Auto Code, www.autocode.com.au
Cheers.
Post #405517 20th Sep 2016 9:43am
http://store.autocode.com.au/egr-emulator.html
Hmm, interesting, I await the results of rar110's install Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #405524 20th Sep 2016 10:51am
rar110
It runs a bit quieter and much less black smoke out the back on acceleration. I read that the EGR helps bring the motor up to temp a bit faster. I tend to give it a little more time to warm up before I give it a boot full. And you don't get the EGR cycling noise on shut down. ______________________________
Post #405529 20th Sep 2016 11:53am
Very tempting for when the RGR's finally throw in the towel.
I wonder of there are any long term issues with doing this? Got - 2017 SDV8 Autobiography in Loire Blue
Post #405534 20th Sep 2016 12:11pm
Rob99
My understanding is that, in the UK it will fail an MOT if the EGR's are by-passed or disconnected.
. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #405549 20th Sep 2016 1:57pm
Whys is that? Does it have an effect on the emissions check? Got - 2017 SDV8 Autobiography in Loire Blue
Post #405552 20th Sep 2016 2:10pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
If it was fitted with EGR from the factory, then it has to be present for MoT. Same for DPF and Cats.
However, testers are not allowed to remove covers to do checks - so if it is completely hidden then it is no problem.
My 'other' car Rover 75 has an EGR bypass that is under the engine cover. My MoT garage knows I've fitted it but can't remove the cover to check, so it passes the MoT. This is why people are now supplying/fitting fake Cats rather than simply bypassing them.
Post #405562 20th Sep 2016 3:09pm
So, assuming the MOT tester probably won't even open the bonnet, it's a bit of a moot point then? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #405581 20th Sep 2016 4:43pm
it is a moot point, however assuming they are plug and play, then you could just plug the EGR back in for the MOT Whistle There is nothing that can't be fixed with a hammer😜😜
Post #405627 20th Sep 2016 8:15pm
rar110
I doubt an inspection would identify what it is if the bonnet was opened. But yes can be put back to factory in a couple of minutes by unplugging the emulators and plugging in the EGRs. ______________________________
Post #405683 21st Sep 2016 8:39am
dolph34
I had my EGRs turned off a few weeks ago and it has stopped the puff of smoke that used to appear on initial hard acceleration It was done while being remapped with no extra cost 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #405773 21st Sep 2016 5:50pm
rar110
Who did the remap? ______________________________
Post #405820 21st Sep 2016 10:13pm
Page 2 of 5 <12345>
