![]() | Home > Technical (L322) > Starter motor replacement L322 TDV8 |
mezo Member Since: 13 Mar 2022 Location: Milton Keynes Posts: 22 ![]() ![]() ![]() |
3 month update since adding a second parallel wire to the existing wire - problem solved, no further starting issues at-all.
Having just experienced a melty busbar on a solar / battery PV system - in that case, the bar was getting warm - which caused the bolt head to pull through the plastic slightly which of course got hotter, pulling it through more until it was open circuit. So it may be the case with the Range Rover bus bars/fuses that just a slight bit of looseness can lead to a run-away effect in the same manner. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
me too, parallel cable from headlight fusebox, to starter trigger wire connection on starter -soldered both ends. . problem gone! so pleased, and so cheap, and EASY! |
Sarchopperman Member Since: 11 Aug 2017 Location: Aberdeenshire Posts: 33 ![]() ![]() ![]() |
This is a very interesting thread. I have the dreaded starter solenoid click and am in the process of replacing it. There is another thread where some sites, Opie being one, identify the Late L322 TDV8 4.4's as early L405's. That is another issue.
ignore - this is the thread in question |
roel2018 Member Since: 01 Oct 2018 Location: Aalter Posts: 36 ![]() ![]() ![]() |
How many hours takes the replacement for the starter motor for the 2011 TDV8 4.4 ? |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
I would say 3 hours, 1.5 in 1.5 out*
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 ![]() ![]() ![]() |
Well done Greg, now you have got another one to refurbish, ready for your 200k anniversary |
Glutofl322 Member Since: 22 Sep 2023 Location: Cumbia Posts: 1 ![]() ![]() ![]() |
I got the dreaded click so went about changing the starter. However upon inspection I can see it's a new starter.
Read back a page or two and see the remedy of a parallel wire for the trigger wire. You can run it temporary, see if it’s clears the fault, then run it in better later on. Somewhere, there is an inherent high resistance connection in the wiring, that no one has yet discovered where. |
RovingCanary Member Since: 20 Dec 2023 Location: Somerset Posts: 79 ![]() ![]() ![]() |
I have had a click a few times - usually on a cold morning. My battery is a bit low (sits around 12.2v) so will change that, and the car starts when I use the NOCO jump pack (or sometimes after a few attempts, and then starts strongly).
yes I fitted. new battery, refurbished my starter (solenoid contacts) and it starts on the button. been many months now. Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Cheers, I will start with a new battery, as it goes fine with the jump pack on, then clean up the starter when summer comes around |
jimmora Member Since: 28 Apr 2024 Location: Atlanta Posts: 2 ![]() ![]() ![]() |
[quote="mezo"]Having lack of start with lowish (~12.3v with accessories on) battery - starter and battery changed and was pointed to this thread.
