![]() | Home > Maintenance & Mods (L322) > radiator change 4.4TDV8 |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1350 ![]() ![]() |
How bad is it?
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Need to remove whole front of the car and get out whole radiator pack. And only then can separate coolant radiator.
paulN186 Member Since: 28 Jun 2022 Location: edinburgh Posts: 39 ![]() ![]() |
It’s getting the work done on Thursday, question is there anything else worth replacing in there when it’s all apart? Save myself some pain in the long run? Damn wasn’t expecting a 1k bill after only owning the car two weeks! 😭 |
Water pump is cheap and worth doing, alternator if you want, idlers and pulleys plus belts, all easy without the rad in the way, guess you didn't fancy the k seal |
