Home > Maintenance & Mods (L405) > L405 Transfer Box Oil Change & Judder Bulletin Double Fl |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 756 |
Yes, you need to use the IID tool. Funnily enough, I did a double flush on mine today followed by a re-calibration of the transfer case motor and clutch using the IID tool. It's simple enough to do. Kev
15th Oct 2022 8:32pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1295 |
Thanks, I’ll sort out the tool soon then. V8 or else ... |
16th Oct 2022 7:27pm |
Col-in-spain Member Since: 09 Mar 2023 Location: Javea Posts: 16 |
I’ve recently done a double flush on my L405 transfer case and until recently I thought it had sorted the low speed judder but it hasn’t, I guess I need to do the re-calibration but I don’t have an iid, is it possible to do it with a icarsoft tool? |
25th May 2023 7:57pm |
Mikeerhymes Member Since: 01 Sep 2018 Location: Manchester Posts: 19 |
Was it possible with iCarSoft? |
19th May 2024 7:45pm |
Its not possible with icarsoft |
19th May 2024 10:02pm |
Thanks Col. I upgraded my diagnostics tool but unfortunately the double flush and calibration has not cured the issue.
25th Jul 2024 2:19pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1450 |
Interesting read. I get a judder on a tight turn between 0-5mph. I assume it's my NSR driveshaft.
25th Jul 2024 3:19pm |
Hi Gary, yes similar symptoms for me too only low speeds, it sounds exactly like a knackered driveshaft/CV. I initially thought rear differential due to symptoms but then stumbled on this thread. I too have full MD history (MY19 50k) but the transfer box fluid doesn’t appear to have made it on their service list.
25th Jul 2024 3:55pm |
I ended up having mine completely rebuilt. New clutches, new bearings, new chain, new solenoid. 4 months on and it's still alright. I'm keeping my fingers crossed.... Kev
25th Jul 2024 8:52pm |
Thanks Kev! I had literally just ordered the Dr. Tranny Instant Shudder Fix after reading your other post doh
25th Jul 2024 9:00pm |
Yeah it sorted it for me for about 12 months the first time I used it. Then when it came back, I did another double flush and put another tube of Dr Tranny in. It lasted about a month or so and at that point, I had to bite the bullet and take it somewhere. The rebuild was about £1300ish all in including removing and refitting to the vehicle.
25th Jul 2024 9:16pm |
I think I'll start with my part-time mechanic hat on. Start with a ramp inspection of the driveshafts and centre propshaft bearing then go from there. 2015 Range Rover Autobiography 4.4 SDV8 |
25th Jul 2024 9:17pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1165 |
same problem for me, My last post
26th Jul 2024 8:25am |
I know this is needle in a haystack territory, but....does this video sound like the transfer box noise you are all reporting?
30th Jul 2024 9:07pm |
