![]() | Home > Maintenance & Mods (L405) > L405 Transfer Box Oil Change & Judder Bulletin Double Fl |
JoeDoyle Member Since: 08 Aug 2024 Location: Eastbourne Posts: 8 ![]() ![]() ![]() |
Did two transfer case oil changes, shudder lessened each time, will do a third change next week. Also did ZF filter and oil, front diff and electronic rear diff, hydraulic/power steering flush. Just purchased with 82k SDV8 the oil changes and adaption resets for each make a massive difference. |
PLOG Member Since: 19 Nov 2018 Location: Teesside Posts: 25 ![]() ![]() ![]() |
Has anyone managed to fix this long-term yet?
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
If a new transfer case hasn't solved it and the TCCM has definitely been updated, it is a possibility that you have a different problem to that of the transfer case judder in this thread. The transfer case judder I was experiencing was quite violent, not slight.
I did a lot of reading about it beforehand and the LR Bulletin was exactly what I was experiencing (and still am), so I was convinced the double flush would work.
knwatkins - Where did the judder / noise feel like it was coming from for you? It feels like it's coming from the rear left on mine. |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Same problem here, after two years of complaining about the clonk, they replaced the rear diff under warranty.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 504 ![]() ![]() ![]() |
is there a bulletin out for this issue ?................its ok i found it |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
second post on page one. ... - .- -.
Did the flush, software update, didn’t work. Changed the transfer case and control module. Judder remained.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
Did the ediff s/w update include recalibrating the ediff? |
Software update to control module, calibration through Gap tool self test. Changed the oil again yesterday, if anything it’s worse now, thinking of trying Dr Tranny
I was surprised to learn that a relatively local to me LR specialist workshop rebuilds ediffs. |
been having this problem ,just done first flush -software updated calibration carried out .......will be driving it around for couple of days then do the second flush and fingers crossed judder sorted |
