Home > In Car Electronics (L322) > Update on Navtool
Page 3 of 7 <1234567>
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
It’s all built in. Follow the instructions on the screen when you switch it on. It’s simple. 😉 Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #645282 10th Oct 2022 4:50pm
Weegie
Wireless is integrated in version 6.0. You’ll be very pleased with it. Thumbs Up John
GAP iiD BT
Post #645286 10th Oct 2022 5:33pm
DanPoole
United Kingdom 2012 Range Rover Autobiography TDV8 Orkney Grey
Excellent, thanks.
Really looking forward to getting it installed!
Just need to figure something out to replace the outdated DVD player for the rear screens now! 2012 4.4 TDV8 Autobiography
2005 4.2 V8 SC
2003 4.4 V8
Post #645290 10th Oct 2022 5:50pm
DanPoole
Genuinely very impressed so far. Ordered Monday late afternoon, and arrived at 9.30 this morning!
Should get a bit of time this weekend to install.
2005 4.2 V8 SC
2003 4.4 V8
Post #645456 12th Oct 2022 6:03pm
DanPoole
One question prior to install tomorrow.
I'm looking to add a Firestick to the HDMI port, which will require a power source. On the installation instructions, it states not to use the USB port for power to the HDMI source?
What's the best alternative other than feeding another wire down to the centre console which I'd really like to avoid? 2012 4.4 TDV8 Autobiography
2005 4.2 V8 SC
2003 4.4 V8
Post #645672 15th Oct 2022 8:34am
DanPoole
Must say, I’m over the moon with it so far. Really brings the car up to date, and works flawlessly. Well worth the investment in my opinion.
Also added a firestick to it so no need to upgrade my old analogue tv tuner to digital.
2005 4.2 V8 SC
2003 4.4 V8
Post #646195 22nd Oct 2022 11:21am
tymh
How does the fire stick work? My TV is a bit rubbish with the reception. Tym
Post #646196 22nd Oct 2022 11:49am
DanPoole
I’ve added mobile wifi to the car, so it connects to that. Also had the firestick ‘cracked’ so can watch any normal station. I just need to work out how to do it whereby the rear screens work off the firestick independently to the front. 2012 4.4 TDV8 Autobiography
2005 4.2 V8 SC
2003 4.4 V8
Post #646198 22nd Oct 2022 12:03pm
Weegie
We toldyou you would be pleased Thumbs Up
Can you explain what you have done in more detail? Also what did you do about power to the firestick John
GAP iiD BT
Post #646203 22nd Oct 2022 2:07pm
DanPoole
So I bought a mobile wifi hotspot along with an unlimited data sim.
TP-Link M7350 4G LTE MiFi,... https://www.amazon.co.uk/dp/B06XC16QC1?ref=ppx_pop_mob_ap_share
The USB simply wouldn’t give enough power to the firestick, so bought the below from Amazon which worked a treat.
Mission USB Power Cable for Amazon Fire TV (Eliminates the Need for AC Adapter) https://amzn.eu/d/5Rfk7tc 2012 4.4 TDV8 Autobiography
2005 4.2 V8 SC
2003 4.4 V8
Post #646205 22nd Oct 2022 2:47pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Question regarding aux in
Quick question for the brain trust. Im considering buying this with wireless CarPlay.
With regards to connecting the aux - I have a bluetooth aux. Will this work though my iPhone?
This is what I have installed
https://britishamericanconcepts.com
Thanks
Alex 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #647080 1st Nov 2022 5:15pm
DanPoole
I’m not sure to be honest, but if you can get it working with Bluetooth let us know! 2012 4.4 TDV8 Autobiography
2005 4.2 V8 SC
2003 4.4 V8
Post #647181 3rd Nov 2022 7:21am
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
Hi,
i am thinking to bite the bullet and order the new version of the navtool - wireless car play sounds great. As i have a aux input via most box i can imagine that i need no cables to run in the front und place the box also in the back (close the bus in the glove box).
Can you answer me some questions:
- It says that the unit uses the original microphone? Can you confirm that?
- Wheel buttons will not work for the unit, no?
Thank you,
Klemens
Post #649527 30th Nov 2022 10:53am
DanPoole
The box is fitted in the rear using the connections to the sat nav unit. The aux cable I’ve run from the rear to the closest aux socket for me which is the rear of the centre console.
The original microphone is used so no need to fit another.
The only steering wheel function that it retains is volume, everything else can be actioned via the touchscreen or your phone.
Hope this all helps. 2012 4.4 TDV8 Autobiography
2005 4.2 V8 SC
2003 4.4 V8
Post #649531 30th Nov 2022 11:10am
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
Re: MY2012 L322 S/C (North American, left hand side steering wheel)
What's the best/easiest route to access the radio module by the glovebox, and the back of the LCD head unit as well? Can I remove the vent covers on either end of the dash, then the middle vent cover, then the center speaker grill, and then screws? Or do I also need to go through removing the gloveboxes too? 2012 Supercharged L322
Post #653414 13th Jan 2023 3:13am
