Home > Maintenance & Mods (L322) > Its Dead Jim ! - MOT failure due to front subframe |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
Its probably the last pic that they took particular dislike to, you might be able to get that patched /welded and get some more life out of it for not too much outlay |
8th Oct 2022 9:24am |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 |
They said they wouldnt weld it as I did mention that.
8th Oct 2022 10:21am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2532 |
Wouldn't the job just take a workshop a few hours if you supplied a good used sub-frame, especially if the bushes are OK so that only new bolts were fitted? |
8th Oct 2022 11:27am |
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 |
A welded "repair" on a sub-frame is a straight fail anyway !
8th Oct 2022 11:42am |
Johnh Member Since: 07 Nov 2011 Location: Rugby Posts: 44 |
I do not think the sub frame is a thin gauge steel pressing, therefore section 5.5.3 should not apply, which would mean the bad on welding it does not apply |
8th Oct 2022 12:22pm |
Jonh It may read differently now I have formatted the MOT guidance and separated the sentences ! The MOT Testers Manual is not a "be all and end all" it is a guide to apply to all vehicles being inspected Heading states "Sub-Frame" - and a welded repair is listed as an "unsafe repair" 2009 - L322 5.0 S/C Autobiography |
8th Oct 2022 12:24pm |
On closer inspection on the ramp they were pointing out other areas that were crumbly on the subframe, another reason why they said they wont weld it.
8th Oct 2022 12:52pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
If the rest of the car is good then it's simply a question of if it's more economical to repair or scrap and buy another. Get some quotes.... 2012 TDV8 Vogue (L322) |
8th Oct 2022 12:58pm |
Plenty of independent LR specialists about
8th Oct 2022 1:43pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 827 |
have a word with the chaps at CSK
8th Oct 2022 2:09pm |
The rest of the car is “ok” in general, apart from a squeaky PAS pump (2nd one in a year or so now).
8th Oct 2022 2:45pm |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 460 |
If the rest of the car is worth it and you can source one they’re not that bad to do and can be done in a day, maybe less.
8th Oct 2022 9:46pm |
a new one wouldnt be worthet for this car to be honest, a good used one (thats been coaked in oil most of its life) is ideally what im after, found s few for £100/£150 on ebay. ideally id view first.
8th Oct 2022 10:42pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7835 |
Can’t an engineering firm “knock one up”, for want of a better expression, using thicker steel and your old one as a template? Or are the costs involved daft?
8th Oct 2022 11:01pm |
