Home > Technical (L322) > Tailgate window side trims. |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
OEM one's have a bolt head, some of the aftermarket ones have a Torx head... |
1st Oct 2022 7:07pm |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 419 |
Want to remove what I feel is an unnecessary ‘TDV8’ badge off the back of the car. Guessing it’s a hairdryer and a piece of string job followed by rubbing the glue off with my thumb before cleaning? |
2nd Oct 2022 10:27pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
Put a thin piece of kitchen towel soaked in white spirit for half an hour on the glued area and it will come off quite easily. I do it on old wheel weight adhesive. Just make sure the towel is really wet. |
3rd Oct 2022 6:55am |
Thanks. I would have thought white spirit would damage the paint? Or would that happen only if left too long? (30 mins seems like a long time!) |
3rd Oct 2022 9:14am |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1390 |
I have always found cup of hot water poured over badge is enough to release sticky and then pry off with plastic tool so as to not damage paint, 2min job and no scratching. That's how I do it anyway for what its worth. |
3rd Oct 2022 10:37am |
If you leave it for 30 mins it will come off easily. I use white spirit for tar spots with no ill effect. Polish it afterwards though. |
3rd Oct 2022 11:36am |
Finally got round to fitting the new oem side trims.
13th Jan 2023 6:37pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
Great news - I've had a pair of trims sitting in the garage for a couple of months now, when I get time to remove the current ones and replace them! Hopefully mine come off as easily... |
13th Jan 2023 7:35pm |
Basic tip - start attaching it from the bottom so you don’t end up with it coming up a little short to the tailgate. I had to attach the first one twice because I didn’t think it through at the outset.
13th Jan 2023 9:57pm |
Super, thanks so much for the tips! Will give it a go as soon as I get some time on a non-rainy day... |
13th Jan 2023 11:25pm |
jonesl757 Member Since: 25 Nov 2024 Location: Bristol South Gloucestershire Posts: 1 |
We have the same problem. Looking for a video for help with removing the old trim and fitting the new ones . Can anyone help . Any advice would be great thank you |
25th Nov 2024 10:25pm |
It was a while ago now but they just pulled off for me.
2nd Dec 2024 6:32pm |
