![]() | Home > Technical (L322) > Tailgate window side trims. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Lower trim, on an early car. No side trims.
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 433 ![]() ![]() ![]() |
Basic question - is removing them as simple as gently (with some force!) pulling them away from the glass? Guess it’s a compression fit and no glue was used? |
Interesting.... my 08MY doesn't have the side trims or lower finisher - even though it still has the original glazing.
I am quite OEM focused (I even change stereos back to the originals and source original dealer stickers which is a bit nerdy I know). There’s a few things I’m sorting out at the rear so I thought I would just get it done, I guess they must do something other than rot after 2 years!
I agree that the gap looks odd, having looked at the pic of the TD6 I had, above… I wouldn’t bother with the sides then unless you desperately want them on. I vote for leaving as is or fitting the lower trim. Don’t think it traps any more water than without. It’s a tight fit…
I agree, the sides look 'add-on' the lower finisher looks 'right' I have the luxury of a freshly repainted bare tailgate to fit so I think I'll be going with the lower finisher but with a metric f*ckton of Sikaflex behind it. Not right for the MY but it'll 'look' right - except to the spotters! |
Part of my thinking of replacing them is I have a suspicion that the edges of the glass have deteriorated / the laminate has started to separate and go a lighter colour. I maybe wrong. I think a new pair fitted correctly should not catch the eye too much (especially as my car is black) but agree the lower section that was never on my 09MY looks like it was meant to be there. Probably because in the original design it was… |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
I removed the lower trim because it was breaking up. I lubed it with dishwashing liquid and tapped it sideways enough to get a good hand grip and then pulled it out. (Tapped with a block of wood between the hammer and the trim to avoid hitting the glass.) Ron B. VK2OTC
Thanks for the advice, seems a sensible way of doing it. What was the condition of the glass edge when it came off for you? |
Interesting, my car doesn’t have the side strips on the tailgate glass and never had a problem with rain dropping in the car when the tailgate is opened.
Well that wasn’t difficult, they almost just slid off! Bit of sandy residue to clean / chip off.
While I was messing about with the rear of car today I thought I’d paint the rusty toe hook matt black, kept catching my eye, again with a black car made sense to sort it out.
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
What model RR do you have and how come so rusty?....asking for a friend |
2009 3.6 TDV8. The car has no rust. But this tailgate bolt has! Reckon the rubber boot could end up being a water bowl at a guess, which would be ironic as it’s probably there to stop it getting wet. That or it’s a crap pattern part. As far as the toe hooks, not sure I have ever seen one that isn’t rusty! |
