![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Well I was hoping to report something but the car is now on the naughty step 🤣. Got the new LR height sensor from Duckworths, put the front up my ramps and managed to get the old one off, but I can’t undo the 2 little torx bolts that hold it to the bracket I need for the new one. I thought the new one might come with new bolts etc…..
The side vent has a bolt underneath, the trim below that pulls away enough to get a 10mm ratchet spanner in.
Thanks, I saw that on a video I watched. The lower trim doesn’t ease out in the middle, the end only moves a bit. Think I might have to look at how the mudflap fits on, as that might be fouling and stopping it coming out more. Will sort height sensor first.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2661 ![]() ![]() |
Height sensor signals are direct connection to the suspenson and damper modules on all LR vehicles at least up to the L663 Defender. The difference with the L405 and later vehicles is that both modules are located in the same container and designed to share the signals where both modules exist. |
The side vents on later vehicles has an extra screw compared with earlier vehicles, as I discovered when fitting genuine mudflaps that came with instructions for earlier vehicles. IIRC the screw is accessed from the front but it was 5 years ago that I fitted the mudflaps. |
Good to know - thanks. I'm sure I've seen height sensor data broadcast on L405 HS-CAN - I can't think what use it would be other than for the 4x4 info screen. |
Current and target heights are possibly requestable via the HS canbus but perhaps periodically broadcast as well as or instead of being requested. |
So…. New front left Genuine LR height sensor fitted. Had to cut the old one off the bracket. You can still feel bumps, but it’s more compliant and the interior trim no longer rattles and creaks. MOT man at 12 to look at the knock.
Good news - once you've got the accelerometer & mechanical bits sorted, I'll calibrate the ride height for you, should be a lot better then. |
Many thanks mate. Seems the knock is the lower front ball joint, ironically, where the new ride height sensor fastens 🤣.
Not a difficult job then, are you having it done or doing it yourself?
It’s still dropping a bit on full lock left, but I just select Normal again. I’m gonna let my MOT man change it when it comes and get MOT at the same time, save doing that at Christmas. I bought a Delphi lower arm. Used them before without issue.
Just 'remind' him that the bolt that holds it into the subframe needs to be tightened and torqued with the weight on the wheels and the suspension at normal height, otherwise it pre-loads the bush and will rip it to shreds quite quickly. |
Ah, makes sense. Thanks. 2011 Range Rover Vogue SE 4.4 TDV8
