Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Except for the current consumed 'crossing' the corrosion - yes, the consumer will be drawing lower current but the circuit as a whole will draw marginally more as the poor connection heats up (a FLIR camera is really good for tracing resistive wiring faults!). Ohm's law is often quoted but never seems to explain the (ultimately) melted connectors & fuses that I see on a weekly or monthly basis. |
18th Sep 2022 3:41pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2523 |
The assumed extra current due to localised heat is just a transfer of heat generation from the device being powered to the poor connection site. As there is no increase in electrical load for the completed circuit there cannot be an increase in power consumed. A different story if there is a leak from a corroded joint to earth, such as when corrosion on a battery terminal that is leaking to earth through moisture as an additional load is involved. |
18th Sep 2022 9:05pm |
But in the end, the connector still overheats and the fuse still ruptures.... Semantics I know, it does illustrate that reality doesn't always conform to proven laws of physics.
18th Sep 2022 9:13pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 |
2012 4.4 TDV8 AB
20th Sep 2022 6:31pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
That’s good news. Ordered height sensor for mine this morning from Duckworths.
20th Sep 2022 6:46pm |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 106 |
Hi all
22nd Sep 2022 9:54am |
Are you measuring the suspension height sensors or the adaptive dynamics (CVD) height sensors, noting that there are 2 height sensors in each physical device. |
22nd Sep 2022 11:33am |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Take a look at this…
22nd Sep 2022 11:38am |
I’m using the IIDTool which doesn’t expose the CVD values. My simplistic thinking is that while there are two outputs (height and CVD) they pull that from the same component that could be faulty. I think I’ve read on this forum that there are two outputs as they use different incompatible communication methods… whereas newer (L405 I assume) now use the single output. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
22nd Sep 2022 11:43am |
The two sensors are exactly the same for the EAS & ADM, the reason for two is that the extra processing required to broadcast on CAN was too much of an overhead at the time, it was considered better to input the signals directly rather than have potential delays or missing messages on CAN. Obviously things have moved on and L405 works happily with network data.
22nd Sep 2022 2:42pm |
I was measuring the Voltage from the height sensor for the suspension via the GAP IID, I don't think we can get the output for the CVD system through the GAP tool, I wasn't aware that the sensor provided two separate outputs. Do we know of a way of reading the output for the CVD from the height sensor? Are these the graphs you mean Pheonix? 2012 TDV8 Autobiography Baltic Blue Previous 2007 BMW M5 E60 |
22nd Sep 2022 2:49pm |
So those graphs suggest the voltage between the two fronts (and applies to the rear) should be the same. My 1v difference would indicate Ann 80mm difference in reported height?
22nd Sep 2022 4:27pm |
You're reading it wrong - 3.1V on the left (green line) is pretty much bang on standard height (zero line) 1.9V on the right (red line) is also pretty much bang on the zero line.
22nd Sep 2022 5:36pm |
Ah, yes now I see that. Thank you for correcting me and giving the very detailed posts Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
22nd Sep 2022 5:41pm |
