![]() | Home > Maintenance & Mods (L322) > Engine oil? |
G3BML Member Since: 22 Jul 2021 Location: Glasgow Posts: 98 ![]() ![]() ![]() |
I just changed the oil and filter in my car this morning and used shell 5w30 AJ-L which meets the approval for the 4.4 TDV8 |
GustavW Member Since: 26 May 2021 Location: Kalmar Posts: 42 ![]() ![]() |
has anyone experience with this oil: Valvoline SynPower ENV C1 5W-30? Fuji White 2011, 4.4 TDV8 Vogue SE |
I guess thats whats best, stick to recommendation from the manufacturer Fuji White 2011, 4.4 TDV8 Vogue SE |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
In my handbook for an Australian market TDV8, it states to use 10w 40 from -10c to +50c climates 2007 TDV8 VSE
Do not use anything other than the correct spec oil esp with a DPF equipped vehicle (Aussie versions came with no DPF) as it needs ‘low ash’ formula. If you want to look after your car the best you can (at any mileage) change it more regularly than the service schedule and it’s an easy DIY job with a suction oil extractor. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
The 4.4 TDV8 DPF needs a specific specification of oil. Using anything different and you're opening up to a world of problems.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
I am not an oil expert
landy95 Member Since: 04 Aug 2021 Location: Hall Green, West Midlands Posts: 79 ![]() ![]() ![]() |
I used Smith and Allan for my 2012 4.4 TDV8 engine oil change it has the recommended Low SAPS Ford WSS-M2C934-B compatibility, they sell it in 5 litres cans or 20 litre barrel. I have had no issues over the last 6 months 4k miles.
Thanks for the link - cheaper than Opie!
I buy the Petronas when on offer and keep it in the garage. Its normally £39 Inc VAT for 10 litres so, same kind of price as Smith & Allen. 2015 Range Rover Autobiography 4.4 SDV8 |
The reason Im asking is because my mechanic has been filling my car up with 10w40 for the last 14000km or so... want to change now to the proper spec and 5w30. He said it will bring greater protection at higher temperatures but I fear the oil is to thick for the engine.
I wouldn't worry about it being too thick as long as it's got the low ash Low SAPS rating. Just drain and refill with the correct type and you will be fine. ( maybe find another mechanic though ) 2012 TDV8 Vogue (L322) |
Thanks!
