Home > Maintenance & Mods (L322) > Engine oil?
GustavW
Sweden
Engine oil?
Hi!
What engine oil do you use?
5w30 or 10w40?
Out of curiosity - some say stick to the recommendations and some say 10w40 is better for a high milage engine etc.
Just want to make my car last as long as possible. What have you opted for and why.
Cheers,
Gus Fuji White 2011, 4.4 TDV8 Vogue SE
Post #641144 27th Aug 2022 9:29pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
I just changed the oil and filter in my car this morning and used shell 5w30 AJ-L which meets the approval for the 4.4 TDV8
Post #641145 27th Aug 2022 9:35pm
GustavW
Sweden
has anyone experience with this oil: Valvoline SynPower ENV C1 5W-30? Fuji White 2011, 4.4 TDV8 Vogue SE
Post #641147 27th Aug 2022 9:43pm
GustavW
Sweden
I guess thats whats best, stick to recommendation from the manufacturer Fuji White 2011, 4.4 TDV8 Vogue SE
Post #641149 27th Aug 2022 9:50pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
In my handbook for an Australian market TDV8, it states to use 10w 40 from -10c to +50c climates 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #641157 28th Aug 2022 1:53am
JayGee
Do not use anything other than the correct spec oil esp with a DPF equipped vehicle (Aussie versions came with no DPF) as it needs ‘low ash’ formula. If you want to look after your car the best you can (at any mileage) change it more regularly than the service schedule and it’s an easy DIY job with a suction oil extractor. 2012 TDV8 Vogue (L322)
Post #641170 28th Aug 2022 7:10am
garyRR
The 4.4 TDV8 DPF needs a specific specification of oil. Using anything different and you're opening up to a world of problems.
The correct specification is:
5W-30
STJLR.03.5005
WSS-M2C934-B
A favourite I like to use is Petronas 5000 FJ. Proper branded oil but inexpensive. If you want to extend the life of the engine, the best and a relatively inexpensive way is to do an oil and filter change regularly, such as every 5,000‐7,000 miles (aka 8,000 ‐ 10,000km). Modern oils are also a filter.
The oil change on the 4.4 TDV8 is the easiest I've ever done - get a bucket, pop off the hose, change the filter whilst draining. Top back up. It doesn't take more than 30 minutes. 2015 Range Rover Autobiography 4.4 SDV8
Post #641178 28th Aug 2022 7:23am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
I am not an oil expert
My understanding is that dpf requires low SAPS, like c1 oil
Dpf does not determine viscosity or ACEA requirements
You may find a higher viscosity C1 oil runs quieter in your engine, and is more appropriate for climates with higher average climate temps such as Saudi
Personally I follow manufacturers recommendation
Why take a risk to do otherwise? Those risks might include oil galleys which are too narrow for the engine oil viscosity chosen resulting in poor lubrication and cooling to vital engine components……
Post #641182 28th Aug 2022 7:35am
landy95
I used Smith and Allan for my 2012 4.4 TDV8 engine oil change it has the recommended Low SAPS Ford WSS-M2C934-B compatibility, they sell it in 5 litres cans or 20 litre barrel. I have had no issues over the last 6 months 4k miles.
https://www.smithandallan.com/product/smit...e-oil-4127 Also own a 1976 Land Rover 101 3.5 V8.
Previously owned 1991 Range Rover Vogue 3.9 V8.
Post #641186 28th Aug 2022 8:23am
landy95
Post #641187 28th Aug 2022 8:24am
JayGee
Thanks for the link - cheaper than Opie!
Unless you are doing a lot of towing or high stress off roading there is no point IMO using expensive oil on these low revving big engines as for everyday driving the main reason you are changing oil is to remove the soot load and that is done by the choice of change interval. Expensive oils also are likely the true synthetics which are better in high stress applications but which conversely are poorer at holding soot in suspension. 2012 TDV8 Vogue (L322)
Post #641189 28th Aug 2022 8:45am
garyRR
I buy the Petronas when on offer and keep it in the garage. Its normally £39 Inc VAT for 10 litres so, same kind of price as Smith & Allen. 2015 Range Rover Autobiography 4.4 SDV8
Post #641190 28th Aug 2022 8:49am
GustavW
Sweden
The reason Im asking is because my mechanic has been filling my car up with 10w40 for the last 14000km or so... want to change now to the proper spec and 5w30. He said it will bring greater protection at higher temperatures but I fear the oil is to thick for the engine.
Can I just drain it using a pump and fill it with the proper oil or is a proper flush necessary?
Anyone whos had the same problem?
Any advice is much appreciated. Cheers Fuji White 2011, 4.4 TDV8 Vogue SE
Post #641240 28th Aug 2022 5:29pm
JayGee
I wouldn't worry about it being too thick as long as it's got the low ash Low SAPS rating. Just drain and refill with the correct type and you will be fine. ( maybe find another mechanic though ) 2012 TDV8 Vogue (L322)
Post #641241 28th Aug 2022 5:34pm
GustavW
Sweden
Thanks!
I will do that right away, just ordered oil:
Valvoline SynPower ENV C1 5W-30 5L X2
Ford WSS-M2C934-B spec.
Will change asap! Fuji White 2011, 4.4 TDV8 Vogue SE
Post #641242 28th Aug 2022 5:40pm
