![]() | Home > Technical (L322) > Towing Electrics - Towing ECU |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I bought my plug in kit from towequipe. Everything you need is in it. Plug n play. Mine didn't require any dealer activation, its made by westfalia and is oem. Ian |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
Thanks for that, I've just looked on their web site and they sell both the loom and ECU together as a kit. Nice one |
Hi,
Thanks Dan, |
I hope this is not seen as hi jacking the thread but I had my tow electrics and removable hitch fitted by the dealer and my suspension doesn't lock at standard hight when connected , wouldn't have it any other way now as it's incredibly useful towing of road and for hitching up and un-hitching.
When towing it is important that outfit stays level. LR never intended the suspension to drop to highway mode whilst towing. Imagine you have a big twin wheeler and your suspension drops, in reality this will make the trailer try and lift the rear of the car.
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 741 ![]() ![]() |
What is this 'DSC' you talk about... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
it be 'dynamic stability control' |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
I could raise / lower mine when I had the caravan attached, used it to roughly level the van |
DSC worked trust me it kicked in once when I lost a wheel on someone else's plant trailer I borrowed, lost a wheel with three and a half tones on |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
Whenever i plug the trailer in i get "check trailer light" but they all work, only have brakes and indicators on the trailer though so you think its looking for something else? 2004 black Vogue TD6 |
Rear lights |
Do Sometimes Coogle ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
