Home > Technical (L322) > Rain Sensor and new aftermarket screen |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
If the rain sensor isn't powered then the setting operates as intermittent.
8th Aug 2022 8:59pm |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 |
I'm not sure, I purchased it from Gray's Actions on the mainland (Aus) then put it straight in the workshop and pulled it to pieces and re-sprayed it, while I was at it I had a new front screen fitted, so i'm guessing it did .
10th Aug 2022 12:21am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 537 |
Update: Autoglass have just left (good response time to be fair) having fitted another screen, same manufacturer same batch number, same result!! Auto wipe still doesn't work. There tech dept has for some completely inexplicable reason (given they must know the issue by now) authorised a replacement sensor. We'll see what this does (I won't be holding my breath mind!). Drives:
12th Aug 2022 10:49am |
Be interesting if the new sensor works, you will probably have to program it before you can test it.
12th Aug 2022 11:23am |
I won't be programming it that's for sure, Autoglass broke it so they can fix it!! Not sure what you mean by r&r Googs? Drives:
12th Aug 2022 1:16pm |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 185 |
Remove and refit. Maybe 2016 4.4 diesel |
12th Aug 2022 1:36pm |
I'll go with that! About an hour and a half, but they were playing with the laptop to try and reprogram the rain sensor (which I'm not sure it needs, but they're supposed to know what they're doing). Drives:
12th Aug 2022 2:44pm |
Not sure what you mean by r&r Googs?[/quote]
12th Aug 2022 7:08pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
Just as a bit of a curved ball suggestion, are you sure that this isn’t the well known issue of the cabling for the auto wipers and lights going belly up?
13th Aug 2022 6:33am |
Can you elaborate a little further Chris, which side, wire color and what parts need removing to find the said wire? It’s worth a look after all I’m not getting any where at the moment! |
13th Aug 2022 7:10am |
All done at home, only minor inconvenience is that you have to leave it for an hour or two to allow the adhesive to cure. Drives:
13th Aug 2022 10:26am |
Hi Googs Here is my post from last year, which may help https://www.fullfatrr.com/forum/topic59796.html 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀 2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone 2004 4.4 V8 Petrol Vogue - now gone |
13th Aug 2022 3:21pm |
5am here in my home town....but as soon as its light ima going searching for the red & green wire i do remember when i brought the RR the screen had been leaking and i lifted the carpet and dried it out...I'm betting you're rite Chris. Report back in a few hours. |
13th Aug 2022 7:07pm |
It’s worth a try. If not, it’s worth eliminating the possibility of it being the cause 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
13th Aug 2022 7:14pm |
