Home > Technical (L322) > Rain Sensor and new aftermarket screen
Page 2 of 5 <12345>
Googs
Australia
So if you have intermittent turned off the rain sensor is active?
Just wondering if the screen is after market and supposedly a little thicker why the damn rain sensor doesn't work.
Post #639068 8th Aug 2022 8:34pm
GraemeS
If the rain sensor isn't powered then the setting operates as intermittent.
Did auto wipers ever work on your vehicle? If not then check that the fuse is fitted.
Post #639074 8th Aug 2022 8:59pm
Googs
Australia
I'm not sure, I purchased it from Gray's Actions on the mainland (Aus) then put it straight in the workshop and pulled it to pieces and re-sprayed it, while I was at it I had a new front screen fitted, so i'm guessing it did .
I checked fuse #41 that's ok so I'm still thinking. Whistle
Post #639144 10th Aug 2022 12:21am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Update: Autoglass have just left (good response time to be fair) having fitted another screen, same manufacturer same batch number, same result!! Auto wipe still doesn't work. There tech dept has for some completely inexplicable reason (given they must know the issue by now) authorised a replacement sensor. We'll see what this does (I won't be holding my breath mind!). Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #639393 12th Aug 2022 10:49am
Googs
Australia
Be interesting if the new sensor works, you will probably have to program it before you can test it.
So how long does it take to r&r the screen ?
Post #639401 12th Aug 2022 11:23am
rvbush
I won't be programming it that's for sure, Autoglass broke it so they can fix it!! Not sure what you mean by r&r Googs? Drives:
Post #639408 12th Aug 2022 1:16pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Remove and refit. Maybe 2016 4.4 diesel
Post #639411 12th Aug 2022 1:36pm
rvbush
I'll go with that! About an hour and a half, but they were playing with the laptop to try and reprogram the rain sensor (which I'm not sure it needs, but they're supposed to know what they're doing). Drives:
Post #639415 12th Aug 2022 2:44pm
Googs
Australia
Not sure what you mean by r&r Googs?[/quote]
Sorry, that means remove and replace (R&R) i was just asking as you have to take car in have them fix so your are without the vehicle for X amount of time, a good inconvenience !
Post #639437 12th Aug 2022 7:08pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Just as a bit of a curved ball suggestion, are you sure that this isn’t the well known issue of the cabling for the auto wipers and lights going belly up?
I had a windscreen replacement a couple of years ago and was convinced that it was responsible for my wipers and lights not working. I bought a replacement sensor but there was no improvement.
It was only when I heard of the wiring issue that I spent an hour checking and found the crimp had turned to powder.
For the sake of an hour of your time it might be worth checking?
Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #639461 13th Aug 2022 6:33am
Googs
Australia
Can you elaborate a little further Chris, which side, wire color and what parts need removing to find the said wire? It’s worth a look after all I’m not getting any where at the moment!
Post #639462 13th Aug 2022 7:10am
rvbush
All done at home, only minor inconvenience is that you have to leave it for an hour or two to allow the adhesive to cure. Drives:
Post #639475 13th Aug 2022 10:26am
chris_read
Hi Googs
Here is my post from last year, which may help Thumbs Up
https://www.fullfatrr.com/forum/topic59796.html 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #639491 13th Aug 2022 3:21pm
Googs
Australia
5am here in my home town....but as soon as its light ima going searching for the red & green wire Rolling with laughter i do remember when i brought the RR the screen had been leaking and i lifted the carpet and dried it out...I'm betting you're rite Chris. Thumbs Up Report back in a few hours.
Post #639507 13th Aug 2022 7:07pm
chris_read
It’s worth a try. If not, it’s worth eliminating the possibility of it being the cause Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #639510 13th Aug 2022 7:14pm
Page 2 of 5 <12345>
