![]() | Home > My Range Rover > My 2005 4.2 Supercharged - here we go.... |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 395 ![]() ![]() ![]() |
Some progress pics over the last few days. Wheel Arches protected, side panels refitted with new clips, Sill protectors fitted, also with new clips. Bumper on too.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8531 ![]() ![]() ![]() |
Great to see someone repairing rust properly, the only way is to remove all rusted metal back to good steel and start again, that looks like an excellent job and should last for years...
Before my SC went into the Bodyshop the rear parking sensor buzzer would continually beep. After removing the bumper and the wiring to each sensor, I tested for continuity along each wire - all OK. So, ordered four new sensors from eBay - https://www.ebay.co.uk/itm/353874134007 and sprayed/lacquered them after roughing them up to provide a key.
Time to put the Genuine and original side steps back on. I remember that when I removed them one side caused me all sorts of fun with the captive bolts in the side of the sill/ rail turning and snapping off.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3192 ![]() ![]() ![]() |
Nice job!
Next job - Towbar.
Just looking at the pictures of your loom.
Its pretty bad David so I'll get one ordered |
Fitted the Westfalia Towbar last night. I needed to cut off the exhaust hanger brackets from the existing arms which I had to do before, when it was fitted to my TDV8 3.6 (2010). I haven't welding them back on - the bolt the bracket passes through is pretty substantial and I didn't when I fitted it before.
Nicely done.
Thanks David. Took a few hours.
So after a proper diagnosis by my Air Con specialist who found a leak in the condensor courtesy of the dye, I ordered a new one from site sponsor Advanced Factors. Ordered it at 9:30 yesterday and it arrived at 11:00 today via DHL. Its not a brand I recognise but looks well made. I'll fit it after work tonight, Regas tomorrow.
Time to replace the old leaking Air Con Condenser... and what a struggle I had. |
Cool...... see what I did there.... |
