![]() | Home > Maintenance & Mods (L322) > Fuel EVAP Canister - Any ideas? |
Ajmngn Member Since: 25 May 2021 Location: Gloucestershire Posts: 194 ![]() ![]() ![]() |
Does anyone know much about or have the part numbers for the EVAP canister in the fuel system?
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Diesels don't have an EVAP system as diesel doesn't evaporate as readily as petrol.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
IIRC isn't there some anti syphon device that can get triggered and give this problem with filling... or am I not remembering right...??? Pete
Weejock - thanks for the suggestion. Misfuel safety flap definitely not the problem. The car has one but it’s not been triggered. I can’t see a breather hose in the space around the fuel filler hole so do you know if I have to get behind the wheel arch lining to check those and what should I be checking to see that they’re clear?
Yeah that is another possibility, the Anti Syphon usually is just a big ball at the base of the filler neck, push anything solid down the filler, like a pipe, and it pushes the ball down preventing anything going past however fuel can go around it.
Since this suggestion I can report that, after trying the upside down pump nozzle on my last two fill ups, I’ve not had a single unwanted click-off! Touch wood that this continues and that no further issues are needing solving (for today at least!! 🤣).
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
Am i getting this right ?
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Yep, insert and fill the opposite way around to how you would normally fill. 2015 Range Rover Autobiography 4.4 SDV8 |
