Home > Maintenance & Mods (L322) > Fuel EVAP Canister - Any ideas?
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Does anyone know much about or have the part numbers for the EVAP canister in the fuel system?
I’m having the problem where the vehicle won’t take much fuel before the pump nozzle clicks off. It’s obvious that the air in the tank isn’t getting out as quickly as the fuel is going in, hence the issue.
Seen a lot of videos on YouTube about this and seems to be one of two things:
- least likely but possible, the hoses that allow the air to get out of the tank are blocked.
- most commonly, the EVAP canister and the charcoal filter are blocked and need replacing as they do have a shelf life.
On my 102k mile 2010 4.4TDV8, the EVAP canister seems the likely culprit due to age and mileage.
I haven’t had a chance to get into details on the workshop manual yet but any info from forum members with knowledge or experience of this would be appreciated!
Many thanks in advance! Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #638822 6th Aug 2022 8:23am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Diesels don't have an EVAP system as diesel doesn't evaporate as readily as petrol.
Check the breather hoses on the filler neck, also it might have a miss fuel device in the filler neck to prevent it being filled with petrol. If that gets activated then it will block the filler neck and would need to be reset, it should be pretty obvious if it's been activated as a yellow pop up sliding cover will be seen down inside the filler neck. There will be a tool somewhere, probably in the boot, to reset it if it has the device. Not sure the UK market 2010 L322 diesels got that device but other LR products in that year did. Could be barking up the wrong tree as I don't if it totally prevents filling once activated or just restricts the flow like the issue you're having.
Post #639215 10th Aug 2022 5:19pm
IIRC isn't there some anti syphon device that can get triggered and give this problem with filling... or am I not remembering right...??? Pete
Post #639219 10th Aug 2022 5:28pm
Ajmngn
Weejock - thanks for the suggestion. Misfuel safety flap definitely not the problem. The car has one but it’s not been triggered. I can’t see a breather hose in the space around the fuel filler hole so do you know if I have to get behind the wheel arch lining to check those and what should I be checking to see that they’re clear?
Haylands - another good suggestion. Do you know anything more about how a potential anti-siphon might work? Andy
Post #639223 10th Aug 2022 6:18pm
Weejock
Yeah that is another possibility, the Anti Syphon usually is just a big ball at the base of the filler neck, push anything solid down the filler, like a pipe, and it pushes the ball down preventing anything going past however fuel can go around it.
This is the principle:
And in practice they look lke this at the base of the filler where it connects into the tank itself (not L322 mind just an example):
It shouldn't really cause issues as even if the ball is forced down fuel can still go around as per the photo above, possibly at a slightly reduce rate which might be your problem or if LR have some weird unconventional design for it!
I guess if the ball is air filled and designed to float allowing fuel around it faster then if it somehow gets punctured and fills with fuel it'll permamantly sit in the lower shut off position. Likewise if it's been jammed down and stuck in the bottom.
Pipework for the fuel tank of the TDV8 can be seen here, the ball would be at the base of the filler neck before the 'rubber' connection onto the tank itself, basically where the clip 8287 is:
I don't know if it is an issue on L322's hopefully a search on here will find out.
I would have thought you would have to remove the wheel arch liner or at least part to see anything, breathers or filler neck.
Post #639235 10th Aug 2022 9:07pm
garyRR
Re: Fuel EVAP Canister - Any ideas?
There's an easy solution to this, which many of us do. Put the pump in upside down and all is well Thumbs Up
The pump will continue pumping and click off only when full, as it should. 2015 Range Rover Autobiography 4.4 SDV8
Post #639245 10th Aug 2022 11:02pm
Ajmngn
Since this suggestion I can report that, after trying the upside down pump nozzle on my last two fill ups, I’ve not had a single unwanted click-off! Touch wood that this continues and that no further issues are needing solving (for today at least!! 🤣).
I do love these forums…full of great ideas and save us all a fortune in the long run! 👍 Andy
Post #640939 26th Aug 2022 9:20am
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
Am i getting this right ?
is this what you mean ?
cheers "it needs some intelligence to undestand you may not have enough"
Post #641033 27th Aug 2022 8:27am
garyRR
Yep, insert and fill the opposite way around to how you would normally fill. 2015 Range Rover Autobiography 4.4 SDV8
Post #641034 27th Aug 2022 8:33am
