Home > Maintenance & Mods (L322) > Wiper linkage grommet fail
JayGee
Crashing of one wiper into another while on holiday in Ireland and part (white grommet on OS linkage) split and not available as a spare. Luckily fashioned a fix by drilling a hole through the boss and reassembling it with a bolt and washers. Will probably make a new grommet on the lathe when I get back but the DIY fix is probably permanent. Managed to straighten the mangled wiper blade as well. 2012 TDV8 Vogue (L322)
Post #639123 9th Aug 2022 5:08pm
These any good....?
https://www.ebay.co.uk/itm/263270459800?fi...SwjodZ6KEa
Or these....
https://www.ebay.co.uk/itm/383662790405 Pete
Post #639125 9th Aug 2022 5:31pm
JayGee
The white plastic part had completely split in 2 so not sure those would work (and I needed it fixed today)
Parking sensor system also failed today…… 2012 TDV8 Vogue (L322)
Post #639126 9th Aug 2022 6:10pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
any good jaygee good breakers
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #639178 10th Aug 2022 11:42am
JayGee
Thanks but I just need the small bush and can make it myself when back home if the repair doesn’t last (which it probably will)
Good breakers BTW for future reference 2012 TDV8 Vogue (L322)
Post #639180 10th Aug 2022 11:55am
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Had the same happen and I drilled it and used a bolt. The wipers still move but I feel more damage was done - either the arms are bent or similar as they just don't clear the windscreen as well as they used to.
Suspect I'll need to replace the whole lot but too scared to check prices and the work involved 😂 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #640271 20th Aug 2022 9:21am
