Home > Technical (L322) > Can’t start & Gearbox fault after jacking |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 275 |
Hi All, I’d appreciate some advice as I’ve gotten myself into a right pickle;
7th Aug 2022 4:01pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3187 |
Sounds like the battery is flat. Can you jump start it in it’s current position? 2012 TDV8 Vogue (L322) |
7th Aug 2022 4:17pm |
Hi JayGee, the battery seems good. Everything powers up and works. It’s only a few months old.
7th Aug 2022 4:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Try a battery reset then.... Pete
7th Aug 2022 4:28pm |
I’ve put it on charge and it does seem to be drawing strongly through the charger; I had left the rear doors open for some hours yesterday whilst refitting various bits of trim so, fingers crossed, the puddle/ interior lights may have drawn down the battery. Here’s hoping! TDV8 4.4 2012 |
7th Aug 2022 4:55pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1463 |
Yes also sounds like a low battery to me.
7th Aug 2022 5:07pm |
Faulty alternator would throw other faults as the charging system is pretty smart at monitoring itself If it fails it fails with little warning from what I’ve researched. 2012 TDV8 Vogue (L322) |
7th Aug 2022 5:16pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
I go with low battery too. Leave it a good 24hrs
7th Aug 2022 6:00pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
DONT jump start it if you can possibly avoid it sir...
7th Aug 2022 11:04pm |
Why should ‘Sir’ not try jump starting his vehicle as long as ‘Sir’ follows the correct procedure? 2012 TDV8 Vogue (L322) |
8th Aug 2022 7:58am |
Because it is not recommended to jump start any modern Range Rover SIR! They quite enjoy munching ECU’s so, it’s highly recommend to charge not jump the batteries… Sir |
8th Aug 2022 8:16am |
The 2010-12 owners manual has detailed instructions to start from another car or booster pack. If there was a potential danger in this it would state recovery to a manufacturer approved workshop was the the required procedure. 2012 TDV8 Vogue (L322) |
8th Aug 2022 8:34am |
Written by the same people who say the transmission fluid lasts the life of the car....
8th Aug 2022 8:38am |
By what physical / electrical process does jump or battery boost starting damage the ECU if done correctly? If there was an issue and owners were frying ECU’s on a regular basis (flat batteries are hardly uncommon on these vehicles) I’d expect it would be a common topic on the forums? 2012 TDV8 Vogue (L322) |
8th Aug 2022 8:49am |
