Home > Technical (L322) > Can’t start & Gearbox fault after jacking |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
That's the good thing about forums, you always get differences of opinion and each individual can decide which advise and experience they want to go with... Pete
8th Aug 2022 8:59am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Wow! Facts huh! There are many… I have been running my own Range Rover based workshops for 30+ yrs sir and it’s been widely understood, since the inception of the 322 jump starting RR’s is a no go! If you absolutely need to jump start a dead RR from this era forward, then corrected fix jump leads and let the one vehicle charge the other from 10-30 mins and then start it!
8th Aug 2022 9:20am |
And I place more emphasis on real life experience, that's the forum again, read all you can from others experience and knowledge and decide which way to go yourself, if you are happy to jump start then that is your choice, my choice would be to charge..... Pete
8th Aug 2022 9:25am |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 275 |
All, crisis averted, it turned out to be a low battery. Car started first try this morning and I’ve taken it for a test drive.
8th Aug 2022 9:40am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3187 |
I know what will happen if I pull the lead from my PC - absolutely no harm whatsoever as the PSU and MB have built in surge protectors. I may loose some data but it won't fry anything. If I connect the booster pack or another car with the correct leads in the correct sequence what are the physical and electrical processes that can fry the ECU? 2012 TDV8 Vogue (L322) |
8th Aug 2022 9:55am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
I've heard jump start horror stories too. I carry my ctek mxs10 charger and 13pin tow electrics adaptor when I go on holiday etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
8th Aug 2022 10:03am |
Glad to hear its sorted Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
8th Aug 2022 10:05am |
I've heard plenty of jump start issues when people use the wrong leads (insufficient current capacity) or connect in the wrong sequence and / or the wrong polarity. I'd like to hear of issues when the correct procedure is followed as this would indicate a major issue in the design of the charging system. I carry a booster pack but not a charger and am now seriously concerned I should be not using it if I get a flat battery. 2012 TDV8 Vogue (L322) |
8th Aug 2022 10:11am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Jumped mine a few times, no worries about it at all, will continue to jump start if its needed in the future |
8th Aug 2022 10:15am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1747 |
Jump started hundreds of modern JLR products, never had an issue, when the correct procedure is followed
8th Aug 2022 10:27am |
And here we go again!
8th Aug 2022 11:31am |
8th Aug 2022 11:49am |
From the workshop manual...
8th Aug 2022 11:50am |
