Home > Technical (L322) > FIXED - PO42D fault and restricted performance
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
Broken down on motorway, have PO42D catalytic converter circuit high, now just got red dpf warning, was yellow for 2mins and I tried the DPF regen but it doesn’t appear to be doing the regen and it has restricted performance as well. Crying or Very sad Crying or Very sad
2012 4.4 TDV8 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #638056 28th Jul 2022 1:04pm
DrRob
Get it recovered to a decent specialist for their diagnosis.....sounds like a sensor has gone maybe..
Workshop Manual - DTC folder - Engine Control Module PDF file shows:
P042D-00 = Catalyst Temperature Sensor Circuit High (Bank 1, Sensor Circuit 2) - No sub type information
Check catalytic converter downstream
temperature sensor for mechanical damage due
to chaffing or heat
Check and install a new catalytic converter
downstream temperature sensor as required.
Refer to the new module/component installation
note at the top of the DTC index
Worskhop Manual is in the Wiki. Scroll right down https://www.fullfatrr.com/wiki/Main_Page Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638061 28th Jul 2022 1:24pm
colalowe
Excellent, thank you!!! Thumbs Up
you don’t happen to know the part number do you?
I’m guessing it’ll have to have the dpf cleaned out now anyway even when I’ve replaced the sensor? 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #638064 28th Jul 2022 1:31pm
DrRob
Sorry, no.
A decent independent LR specialist should be able to accurately diagnose and fix Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638108 28th Jul 2022 8:59pm
garyRR
Here's the diagram for the exhaust system. There's a number of exhaust temperature sensors because it's a V8 - there's a set on each bank. 5 temperature sensors total.
9J460A, B, C and D
A (x2) - LR022894
B - LR022906
C - WDN500130
D - LR052169
If the fault location is bank 1 then, that is passenger side (right of the diagram).
HOWEVER....
I'd actually start at the basic potential causes first, before replacing the sensors. When was the MAP sensor last cleaned? Has the intake manifold been inspected for cracks in the hoses? Has the top hose seal been inspected for failure?
Fault codes are usually consequential and these are the usual suspects which cause DPF and exhaust gas fault codes. 2015 Range Rover Autobiography 4.4 SDV8
Post #638120 28th Jul 2022 10:38pm
colalowe
HI GaryRR
Thanks for the diagram, I have just cleaned the MAP sensor last week when I replaced a sensor on the left side of the Oil cooler, I had the plenum off and it had a load of crud inside so cleaned it all out. The hoses all looked good too.
I have the PO40D code that's been on there for ages, I had left it as Id seen a lot of posts saying to just ignore it, but I have just recently seen a post where the op had the same code and he replaced the manifold sensor which then cleared the code.
So I intend to get this manifold sensor changed and then the manual states the P042D code is caused by sensor downstream of the catalytic convertor so Ill change that as well and see if it cures the problem, if not its off to a specialist. 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #638155 29th Jul 2022 9:47am
garyRR
Which manifold sensor? 2015 Range Rover Autobiography 4.4 SDV8
Post #638158 29th Jul 2022 10:10am
DrRob
P040D is the exhaust gas temperature one in the left hand (passenger in UK) exhaust manifold Thumbs Up
Swine of a job but great DIY write up on here in Wiki Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638168 29th Jul 2022 11:42am
colalowe
Just ordered two sensors and a removal tool,
RANGE ROVER EXHAUST GAS TEMPERATURE SENSOR RANGE ROVER DPF SENSOR LR022906 OEM (after cat/DPF sensor)
RANGE ROVER 4.4 TDV8 EXHAUST GAS TEMPERATURE SENSOR LR052169 OEM 4.4 TDV8 ALL (Manifold sensor)
Ill get these changed and fingers crossed the DPF will regen and it all works ok again.
Not looking forward to replacing the manifold sensor, have seen the write ups, can be done but a pig of a job. 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #638172 29th Jul 2022 12:32pm
DrRob
Keep us posted.
The GAP IID Bluetooth now has a beta DPF regen option. If you don't have one already then get one. It will save you a heap of stress, cash and mither. It will also hold its value incredibly. Mine is always in the glove box. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638183 29th Jul 2022 1:26pm
garyRR
I best update my IID then!
On a separate note DrRob and apologies for a slight hijack here - do you know if there's any way to adjust the cruise control follow distances on its ECU? I find the follow distances way way too large. Number 1 is what I would call a standard following distance with about a 3 second gap, when I think this should really be calibrated as number 2 or 3.
Or maybe worth me asking GAP? 2015 Range Rover Autobiography 4.4 SDV8
Post #638184 29th Jul 2022 1:31pm
DrRob
PM sent to avoid "thread contamination" Rolling with laughter Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638189 29th Jul 2022 2:38pm
colalowe
Update
So the sensors and removal tool both arrived today so,
I thought I would start with the easy one in the exhaust in front of the DPF. Had soaked it in freeing off fluid first then tried a long spanner on it but it was a 12 sided spanner and it felt like it was going to round off.
I got out one of my 6 sided deep sockets and cut off the wires and had a go with this, it felt like it was starting to budge and then 'SNAP' the nut has come off but the thread is still inside the exhaust!! Big Cry Censored L
Anyone know of a good Landrover garage in Lancashire, I think the exhaust will need to be removed now to drill out the old sensor. Rolling Eyes Big Cry 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #638253 30th Jul 2022 2:43pm
I know it won't help you much now but I've had success in the past in shocking the sensors undone, hold the spanner on with one hand and then whack it with the palm of the other hand, creeping up on it by just applying more and more force doesn't usually end well... Sounds weird but it works for me...
Hope it gets sorted for you soon.... Thumbs Up Pete
Post #638257 30th Jul 2022 3:51pm
colalowe
Dropped the car off at a Landrover specialist today, they are going to drill out the snapped sensor and replace it then replace the manifold sensor, hope to get it back at the end of the week and fingers crossed the new sensors sort the issues out. 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #639852 16th Aug 2022 5:51pm
