Home > Technical (L322) > airco when started, driving only hot air
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
As above. Comming back from Amsterdam airco stopped working, although pump was turning.
Stopped for petrol. Drove away, airco worked for 3 minutes or so, then only warm outside air.
Regassed when arrived home, no leaks, good pressure 10.7. Same problem.
Back to specialist, he can not enter the heat/airco system with his pc.
Tried hard reset, to no avail
If airco works, left side has colder air as right side...
They really did their best checked what was possible and are at the end of their wits.
Any of you educated people has an educated guess?
Post #637012 16th Jul 2022 3:08pm
DrRob
4.4 tdv8? Could be the known valve failure on the air con compressor Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #637023 16th Jul 2022 3:57pm
DrRob
New pump sorted mine. Used Advanced not Genuine. Same part, different box Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #637024 16th Jul 2022 3:58pm
Robert
Thanks Dr. Rob, in fact it's a 4.4 petrol AJV8. We will look into this valve failure.
Did not show up on my GAP tool.
Post #637040 16th Jul 2022 7:21pm
DrRob
Not sure if it applies to a petrol one. Only know it’s common on the 4.4 tdv8 Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #637063 17th Jul 2022 7:36am
garyRR
Re: airco when started, driving only hot air
Does the air conditioning no longer work at all? Does heating work properly? There's not too much which would cause the issues other than:
1. Cabin temperature sensor
2. Blockage in the A/C system
3. A/C compression RCV valve is stuck or the clutch isn't engaging - a twin tester should be able to tell you if there's too much or too little pressure on either side of the system and IID has an option to show compressor clutch.
As always, I would also try disconnecting the battery for 5 minutes first. 2015 Range Rover Autobiography 4.4 SDV8
Post #637065 17th Jul 2022 8:00am
Robert
Thanks Gary,
Airco works when engine is started and stops after a few miles driving.
When working left side colder as right side. Heather works
hard reset done,
clutch is engaging, hear it engaging when airco is switched on
cabin temp sensor is ok (according to specialist)
do you know where to find this option on IID?
pressure on high side is 10.7 (low side don't know)
blockage would mean pressure on high side would rise when airco is on??? doesn't it?
Post #637090 17th Jul 2022 2:04pm
garyRR
In the IID tool go to live values and then the full list. You can view the evaporator temperature, clutch status, pressure, cabin temperature.
Trigger these on a drive and see if anything doesn't look right. 2015 Range Rover Autobiography 4.4 SDV8
Post #637091 17th Jul 2022 2:09pm
Robert
Thumbs Up Thumbs Up thanks, great, going to try
Post #637093 17th Jul 2022 2:12pm
Robert
to no avail. On my IID in the live values these items are not available in the complete list, or I am to dummmm to find them.
Next to that most of the temp. measurements in live values give a N/A
While doing this it's (35 ° here) the airco was working fine, went for a ride and it stopped working....? really weird
Post #637095 17th Jul 2022 3:12pm
Couple of things to check, is the aircon dripping from under the car, if not the drain could be blocked and the condensate is backing up and freezing so stopping air getting through...
Also, is cabin filter clean and not blocked...? Pete
Post #637139 17th Jul 2022 6:01pm
Robert
Thanks hayland, yes checked both, clean and works
Post #637142 17th Jul 2022 6:20pm
Oh well... it seems a very funny issue, good luck I hope you sort it soon... Thumbs Up Pete
Post #637144 17th Jul 2022 7:01pm
