Home > Technical (L322) > airco when started, driving only hot air |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
4.4 tdv8? Could be the known valve failure on the air con compressor Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Jul 2022 3:57pm |
New pump sorted mine. Used Advanced not Genuine. Same part, different box Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Jul 2022 3:58pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2288 |
Thanks Dr. Rob, in fact it's a 4.4 petrol AJV8. We will look into this valve failure.
16th Jul 2022 7:21pm |
Not sure if it applies to a petrol one. Only know it’s common on the 4.4 tdv8 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Jul 2022 7:36am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
Does the air conditioning no longer work at all? Does heating work properly? There's not too much which would cause the issues other than:
17th Jul 2022 8:00am |
Thanks Gary,
17th Jul 2022 2:04pm |
In the IID tool go to live values and then the full list. You can view the evaporator temperature, clutch status, pressure, cabin temperature.
17th Jul 2022 2:09pm |
thanks, great, going to try |
17th Jul 2022 2:12pm |
to no avail. On my IID in the live values these items are not available in the complete list, or I am to dummmm to find them.
17th Jul 2022 3:12pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Couple of things to check, is the aircon dripping from under the car, if not the drain could be blocked and the condensate is backing up and freezing so stopping air getting through...
17th Jul 2022 6:01pm |
Thanks hayland, yes checked both, clean and works |
17th Jul 2022 6:20pm |
Oh well... it seems a very funny issue, good luck I hope you sort it soon... Pete
17th Jul 2022 7:01pm |
