Home > Technical (L322) > Hesitation, Red Restricted Perf, hardly runs, codes…4.4 TD
Page 2 of 3 <123>
DrRob
Looking forward to the diagnosis and fix Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #634496 13th Jun 2022 9:09am
Avityesboy
UPDATE
Soooo, it’s been at Mark Smiths for a few weeks now and still no definitive diagnosis…so they have taken the exhaust off before the DPF to rule that out…also removed the inlet to rule that out too….still won’t start unless on easy start then runs really rough on that…they’ve checked all 3 fuel pumps and the pressure and that’s ok too..
They mentioned some back smoke from the inlet which they are thinking is indicating a probable valve problem…argh…
I’ve checked my fuel receipt so it’s not petrol in the diesel….
The costs at the minute are reasonable and they didn’t want to run me up a massive bill to not get anywhere which is fine….
So I’m going to get it recovered back to my parking and attempt to do the next stage myself, I need to remove the injectors so I can compression test each cylinder…and depending on them results if ok send the injectors away after checking if timing is ok…
Does that seem like the sensible next option? I just think the next step is to do a compression test…
It’s also available as a non runner depending on what I get offered…
Post #636732 12th Jul 2022 3:44pm
GraemeS
Has it been confirmed that exhaust gases are getting out the back to indicate that the rear muffler isn't totally blocked in case it has collapsed internally?
Post #636775 12th Jul 2022 9:04pm
Avityesboy
Yes mate, it’s been disconnected before the DPF
Post #636783 12th Jul 2022 9:39pm
JayGee
Just thinking aloud but black smoke in the inlet could also be EGR related. These are not a common fail on these engines and neither are valve issues. 2012 TDV8 Vogue (L322)
Post #636793 13th Jul 2022 8:09am
GraemeS
Is restricted performance still showing with the ign on but the engine not yet started?
Monitoring live values for critical sensors such as the crankshaft position sensor and camshaft position sensor for those few seconds that it fires might reveal something amiss, such as an erratic or even missing crankshaft position sensor signal.
Post #636794 13th Jul 2022 8:25am
Avityesboy
Not sure I’ll see when I get it back but I’d have hoped the specialist would have checked that already…
Post #636829 13th Jul 2022 1:54pm
Avityesboy
UPDATE!
So I collected it back from the specialist, and just out of interest I took the oil cap off to reveal NO CHAIN on the cam sprocket inside there!
So the chain has failed…first question is it a safe engine or interference? I’m fearing the latter as the running got worse and now will hardly start so fearing bent valves etc…
Post #638045 28th Jul 2022 11:02am
dingg1
Not a good advert for Mark Smith is it?
Good luck getting it sorted
Post #638050 28th Jul 2022 11:49am
Avityesboy
In their defence I’d say it seems very uncommon for engine chain problems on these…nobody seems to have heard of this problem before on these engines…
Also I can gauge by the little info I’m gaining both on here and the Facebook group that it’s a very rare fault I guess..
Post #638135 29th Jul 2022 6:23am
DrRob
That is very rare.
What next? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #638138 29th Jul 2022 7:14am
garyRR
Hmmmm, a workshop should really be viewing an issue with an open mind and know fault codes are often consequential. An engine not running / running rough is unlikely to be exhaust related and more what you started looking at block related e.g. cylinders, timing, injectors.
I also havent read of timing chain issues on this engine, only the 5L being a problem. I guess next stop is to a specialist, engine out and heads off to start looking at damage to see whats salvageable? 2015 Range Rover Autobiography 4.4 SDV8
Post #638149 29th Jul 2022 8:12am
Avityesboy
Thanks guys, think the next plan is to start stripping it a bit myself as don’t want to throw money at it anymore, it owes me not far shy of 10k urgh..
I would take 4K for it as is if anyone is interested.
Post #639429 12th Aug 2022 5:18pm
Avityesboy
Post #639438 12th Aug 2022 7:11pm
Avityesboy
Anyone know if this is an interference engine? I can’t find anything online..
Post #639467 13th Aug 2022 8:54am
Page 2 of 3 <123>
