Home > Technical (L322) > Hesitation, Red Restricted Perf, hardly runs, codes…4.4 TD |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Looking forward to the diagnosis and fix Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Jun 2022 9:09am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Has it been confirmed that exhaust gases are getting out the back to indicate that the rear muffler isn't totally blocked in case it has collapsed internally? |
12th Jul 2022 9:04pm |
Avityesboy Member Since: 27 Apr 2022 Location: Kidderminster Posts: 24 |
Yes mate, it’s been disconnected before the DPF |
12th Jul 2022 9:39pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3195 |
Just thinking aloud but black smoke in the inlet could also be EGR related. These are not a common fail on these engines and neither are valve issues. 2012 TDV8 Vogue (L322) |
13th Jul 2022 8:09am |
Is restricted performance still showing with the ign on but the engine not yet started?
13th Jul 2022 8:25am |
Not sure I’ll see when I get it back but I’d have hoped the specialist would have checked that already… |
13th Jul 2022 1:54pm |
UPDATE!
28th Jul 2022 11:02am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Not a good advert for Mark Smith is it?
28th Jul 2022 11:49am |
In their defence I’d say it seems very uncommon for engine chain problems on these…nobody seems to have heard of this problem before on these engines…
29th Jul 2022 6:23am |
That is very rare.
29th Jul 2022 7:14am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1464 |
Hmmmm, a workshop should really be viewing an issue with an open mind and know fault codes are often consequential. An engine not running / running rough is unlikely to be exhaust related and more what you started looking at block related e.g. cylinders, timing, injectors. I also havent read of timing chain issues on this engine, only the 5L being a problem. I guess next stop is to a specialist, engine out and heads off to start looking at damage to see whats salvageable? 2015 Range Rover Autobiography 4.4 SDV8 |
29th Jul 2022 8:12am |
Thanks guys, think the next plan is to start stripping it a bit myself as don’t want to throw money at it anymore, it owes me not far shy of 10k urgh..
12th Aug 2022 5:18pm |
12th Aug 2022 7:11pm |
Anyone know if this is an interference engine? I can’t find anything online.. |
13th Aug 2022 8:54am |
