Home > Technical (L405) > Multiple warnings! SOLVED
Page 1 of 3 123>
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
While driving out of petrol station this morning, I got multiple warnings showing. Car is not driving as it should (heavy steering, slow gear changes, no speedometer reading, sluggish etc). No lights on the Terrain Response section. I’ve tried cycling the ignition several times to no avail. Any ideas?
Post #635907 2nd Jul 2022 10:37am
Merchy
I am not familiar with L405's, but first things I would check are battery voltage, (Try charging the battery? ) tightness / condition of cables etc, low voltage can produce a multitude of faults. I would start there and also look to see if there has been any water ingress to any control units, ( under seats etc, check info in wiki )hope this helps you start the diagnosis.
Post #635909 2nd Jul 2022 11:08am
Merchy
Just read the 'Car just died, any ideas' thread and a quote from garyRR says -
'The erranous gearbox fault error is a pretty good sign of low voltage I.e battery. The ECU on the ZF box immediately flags an error when voltage is too low'
Another sign for voltage problems can be unrelated faults, such as gearbox and camera system faults
Post #635910 2nd Jul 2022 11:18am
kgeddes
Thanks Merchy, the battery seems ok, started fine this morning then 5 minutes later on leaving petrol station these messages appeared. I’ve left the car sitting unused for 3 - 4 days and no issues with starting. It does look like the messages you get when the battery is flat and you try to start the engine. I’m wondering if a hard reset would resolve it?
Post #635911 2nd Jul 2022 11:29am
Merchy
Sounds like a plan, make sure the battery is fully charged first and then do the reset, at least these first moves won't cost you anything and may get a result.
As I said, I know a little bit about L322's, and have only read about L405 problems. On the L322 you probably know that you can access the hidden menu on the screen and read the battery charging voltage when the car is running etc I would think that this is also possible on your car? Just a thought, this would give you extra info for diagnosis hope this helps Thumbs Up
PS - From what I have read on here, lots of times the battery will have enough voltage to start the car, but then low voltage causes the problems when the car is running.
Post #635914 2nd Jul 2022 11:44am
AnotherMutley
My money is on your battery, you started it, stopped, filled up and then started it again, its the cranking that will take the most out of your battery.
I'd try getting it checked by a reputable auto electrician, or a decent autofactors.
Post #635920 2nd Jul 2022 12:16pm
kgeddes
Can’t get into battery as tailgate won’t open! Any suggestions?
Post #635922 2nd Jul 2022 12:26pm
CS
If you can open the bonnet you could try jump starting it by connecting to the positive and negative posts under there. I found a 'Lurgs how to' video on Youtube that showed where these are, but it should also be in your manual and elsewhere. Only Range Rovers since 1988
Post #635926 2nd Jul 2022 1:26pm
kgeddes
Thank you. The car is starting no problem. It’s all the warning lights that are the problem!
Post #635935 2nd Jul 2022 3:55pm
CS
Hmm. You could maybe connect a charger to the posts under the bonnet and see if having the battery really fully charged makes a difference. After that I'd be off to the dealer for diagnostic checks, but depending on where you are in Argyll it won't be that near/convenient. Can you get at the wiring loom to see if any connectors are loose/corroded/wet etc? Only Range Rovers since 1988
Post #635947 2nd Jul 2022 8:13pm
Mikey
Earth points in the front wheel arches are a common area for issues like this
Easy to check and resolve Thumbs Up
Post #635952 2nd Jul 2022 9:33pm
kgeddes
Thanks Mikey, a bad/loose connection makes sense. Can you point me in the direction of the earth points please? Thumbs Up
Post #635957 2nd Jul 2022 10:50pm
Merchy
Apparently there is an earthing point near the fuse box in passenger footwell.
The below is the only other thing I have found relating to L405 earths, I do not know if this applies to your car.
https://www.google.com/url?esrc=s&q=&a...ehptmmBqXm
Hopefully someone should be able to point you in the right direction soon
Post #635961 3rd Jul 2022 7:46am
Mikey
Front of front wheel arch, one either side Thumbs Up
Post #635967 3rd Jul 2022 10:37am
kgeddes
Many thanks Mikey, appreciated Thumbs Up
Post #635975 3rd Jul 2022 12:30pm
Page 1 of 3 123>
