![]() | Home > Technical (L405) > Multiple warnings! SOLVED |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
Thanks again Merchy |
Brerfox Member Since: 22 Dec 2021 Location: Wales Posts: 16 ![]() ![]() ![]() |
just a thought have you checked to see if all your belts are intact and tight? |
Does anybody know if I can get into the boot area - the button and remote are not opening it. It has executive seating so climbing into the boot appears to be impossible! |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
I am assuming that you were on your hols when this all started -
Thanks again Merchy, fault code U0121-00 (abs module) appears in a lot of the list of faults. The biggest issue I have at the moment is getting into the boot area as it’s electric and won’t open, made worse as I can’t climb in (see above post)…I’m hoping the IID Tool can open it! |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1804 ![]() ![]() |
Have you checked the earth's in the front arch, as previously advised? |
Mikey's idea would be a good place to start - also if you want to charge the battery from under the bonnet, check the below thread, including pics. As before on the screen on the L322 you can get the battery charging voltage on the display, I would think this SHOULD be possible on yours, but don't take this as gospel.
Hi Mikey, I’m just back from holiday today and ordered an IID Tool whiltst I was away. I haven’t checked the earthing points as the supplying garage has told me this afternoon to take it to a main dealer to have it repaired, at their expense…..many thanks for your guidance and I’ll let the forum know the outcome…..the unlocking tailgate is a mystery in all this. Thanks again ![]() Ps. I intend to come to you guys for my 120 month service…my mother lives in Crail, Fife so you’re not too far away ![]() |
See the thread -
Thanks again Merchy, I’ve just read that thread - pretty much identical IID Tool fault list I have (with the exception of the tailgate which won’t open)…I’m sure the earth connection/s will be the cause. I’ll give the dealer the IID faults list and Mikey’s suggestion. Next thing is to arrange for a recovery truck to take it there on Monday - 160 mile round trip! |
Well, it got worse (flat battery) then it got better (after jump start the tailgate came back to life). I think I’m going to have a look at the earth connection in the o/s/f wing tomorrow.
Correct, just the front part |
Well done Mikey! Exactly as you diagnosed - earth connection under o/s front wing…..well done! |
Quite common, you see
