![]() | Home > Technical (L405) > Multiple warnings! SOLVED |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1310 ![]() ![]() |
Surely the dealer should fix cracked actuators under your warranty? 2018 SE SDV8 4.4 Byron Blue |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
I don’t have a Land Rover warranty…. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1802 ![]() ![]() |
They won't fix themselves, and will eventually fail due to water ingress into the unit
Thanks Mikey…I’ve already sent the supplying garage the quoted cost….
JakeyKev Member Since: 07 Jul 2023 Location: Scotland Posts: 5 ![]() ![]() |
Sorry for the dumb question here... but is it the front section of the wheel arch that needs to be removed to access the earth points? So take wheel off, remove plastic and should be visible. Thanks |
Update on my issue, might help others.
Kev the Rev Member Since: 07 Jan 2024 Location: Ripon Posts: 43 ![]() ![]() ![]() |
it's a common fault. Check out YouTube, there are loads of videos on it.
