Home > Technical (L322) > 2011 4.4 tdv8 - Strong smell from exhaust
Garnerj
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Recently been getting what I think is a strong smell of exhaust fumes as if the car is chugging out soot! Tend to notice it after a run and we park up and have the car running but also does it at startup too. No real visual black smoke from the tailpipes but the smell is really strong.
No faults registered, and a smoke test shows no intake leaks!
It’s not got a massive soot reading for the dpf and isn’t doing a regen at the time either as my IID tool Allows me to check this.
I’m at a bit of a loss really!
Any thoughts and suggestions of what to look at next?
Post #635317 23rd Jun 2022 9:44pm
No codes at all?
Post #635323 24th Jun 2022 12:04am
Garnerj
Just the usual ones like random stereo ones and a few other bits. I reset earlier and going to take it for a drive again in the morning to see what’s come back.
Post #635324 24th Jun 2022 1:53am
JayGee
Mine smells all the time - as have all my diesel cars ( not that this helps)
I wonder with the current fuel crisis and the particular shortages of diesel if the quality at the pump is what it was? 2012 TDV8 Vogue (L322)
Post #635327 24th Jun 2022 7:39am
Pysta
Slovakia 2011 Range Rover Vogue TDV8 Fuji White
Does it smell only from the exhaust (interrupted regen, shot DPF ...), or under the bonnet (fume leak around EGR, under injector, headers)?
Post #635328 24th Jun 2022 7:40am
I’m suspecting you will have a P3040D code in there when you check later… The temp sensor fails lots on the 4.4 which leads to overfueling and stinks like an old ice cream van!
Post #635346 24th Jun 2022 11:42am
Kot
So you think the quality has got worse now we dont have Russian diesel? I think not Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #635355 24th Jun 2022 1:18pm
DrRob
Listen to Craig Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #635403 24th Jun 2022 6:57pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I had the exact same issue, no codes but changed the sensor anyway just in case. Made no difference whatsoever 2011 TDV8 Vogue SE
Post #635558 27th Jun 2022 7:10am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Camshaft position sensor? Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #635562 27th Jun 2022 8:54am
dennij
No, this is the sensor located in the N/S exhaust manifold 2011 TDV8 Vogue SE
Post #635563 27th Jun 2022 8:58am
Daz90
I think I may have this issue.
Need to confirm but is this an easy fix DIY job?
May I ask what the name of this temperature sensor is?
Post #703757 4th Nov 2024 7:05pm
