Home > Technical (L322) > Pre-heat problem
RobsterPC
Pre-heat problem
As autumn is now here and temperatures are starting to drop, I thought I'd try the pre heat on my Westie today. The fob works, the fans come on and I can hear some clicking and whirring in the car. So I put the dogs in the boot and head inside for a few bits. I come back out and open the boot, the interior smells a little of diesel but I put this down to the system not being used for a while, shut the boot and head back inside.
When my son comes out his first words are "That's a bit of a problem." And he was right.
I shut off the pre heat and the smoke cleared pretty quickly. It smelled of diesel. I suspect there's a leak on or around the pre heater itself. Before I set something on fire or gas myself or the dogs, any suggestions on where to start?
Post #703354 29th Oct 2024 10:37am
kevinp
I'm afraid that's not unusual mate. Mine does it.
The element and the chamber are probably all sooted up. If you are lucky it will burn off and be OK over a few uses.
I think mine needs a new 'chamber' which you can buy seperatly.
Post #703356 29th Oct 2024 10:59am
kevinp
Like this. Thumbs Up
Post #703358 29th Oct 2024 11:13am
RobsterPC
I'm assuming its behind the arch liner in the left wheel well? I'm going to do some preventative rust treatment in there at the weekend so I can take a look then and see where the smoke is coming from. 2nd hand heaters are going for £90, I dread to think how much a full OE unit is.
For reference, the kit above is on eBay here
Post #703363 29th Oct 2024 12:04pm
mjdronfield
The exhaust for the fuel burning heater is down near the mudflap. It’s normal to see something from there when the preheat is running, but as to how much and for how long I’m no expert….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #703364 29th Oct 2024 12:16pm
kevinp
Yes. you can get a refurbed one for about £100.
Post #703366 29th Oct 2024 12:42pm
RobsterPC
I had the arch liner off, the exhaust from the heater wasn't plugged into the unit! I don't know how that would have happened as it was quite a struggle to get the exhaust back on. I've not had the chance to check it since but could that have created the smoke and the smell of diesel? There's not much to the exhaust, though there is some sort of small box on it? Anyway, I'll try it again on the next cold morning we get and see if that's fixed it.
Post #703480 31st Oct 2024 10:41am
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I know nothing about these heaters and my 07 3.6tdv8 is, I think, not fitted with one. However, in a parrallel universe, my step son has recently fitted a diesel heater as part of a camper van conversion. Boy that thing makes some smoke for a while until its warmed up but thereafter there's virtually nothing visible from the exhaust.
Chris
Post #703486 31st Oct 2024 11:36am
mjdronfield
Agreed, that should have resolved the issue…… onwards and upwards 🤣.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #703488 31st Oct 2024 12:40pm
Weegie
Chris
Fitted as standard on diesels. Thumbs Up John
GAP iiD BT-Sold
Post #703533 31st Oct 2024 10:22pm
^ my 3.6 had one, was mostly broken most of the time…. There is nothing that can't be fixed with a hammer😜😜
Post #703644 3rd Nov 2024 10:00am
RobsterPC
To close this out, I tried the pre-heater again today and after having relocated the exhaust, everything is now working as it should. No more smoke or dodgy smells. Its nice to have such a simple fix!
Post #703784 5th Nov 2024 10:32am
