Home > Technical (L322) > Resonance/groan when accelerating 2012 4.4 TDV8
KristoffL322
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Hi guys, my 2012 4.4 TDV8 Westminster has started to make a noise when I accelerate gently. It’s hard to describe but it sounds like it comes from the front of the car, and its almost like the resonance noise you get when blowing across the top of a beer bottle, it happens at all speeds but is more noticeable when going from a standing start to around 25 mph at around 1000 rpm, if you accelerate though it it stops. The car drives perfect and I’ve no warning lights on.
Anyone any ideas on what that might be? It doesn’t sound like wheel bearings or cv joints, or gearbox type noise, almost sounds like something vibrating a certain resonance, then stopping. The car has recently been in the garage for new rear shocks and rear subframe bushes, and to clean up a small oil leak in the engine bay. I can live with the noise, it’s a 10 year old 100k mile car so noises come and go, but I wondered if it was a precursor to anything serious?
Post #635051 20th Jun 2022 11:04am
GraemeS
Check that the spacers separating the brake pipes in the vicinity of the master cylinder are keeping the pipes apart. One of mine's spacers had come unclipped allowing 2 pipes to vibrate against each other.
Mine gets a terrible drone / vibration when the mount at the back of the transfer case gets filled with mud which has dried, which then has to be dug out using a large screw-driver.
Post #635052 20th Jun 2022 11:56am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Could be the beginning of the exhaust heat shield coming loose below the drivers feet. I'm getting this on my 2012 4.4 just now and it is between 1k - 1.5k revs. Just haven't had the urge to get underneath to resolve it yet! Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #635053 20th Jun 2022 12:23pm
JayGee
I get it as well. Only happens at just above idle revs ( I only hear it at low revs) Doesn't sound mechanical to me more like a valve or resonance on the intake. On my old Saab the turbo bypass valve was also known as a 'hooter' valve and made a similar noise. 2012 TDV8 Vogue (L322)
Post #635055 20th Jun 2022 1:16pm
KristoffL322
A valve or resonance on the intake is exactly how it sounds to me, thats a better way of describing it than what I managed in my orginal post.
Also happening for me just above idle too. Wonder what it is??
Post #635058 20th Jun 2022 1:56pm
Umiar
Poland 2011 Range Rover Vogue TDV8 Zambezi Silver
I have exactly the same buzz noise when accelerating. Only at low revs. But it somehow is correlated with engine revs - and I can "feel" it in my right foot when pressing acceleration pedal
Post #635149 21st Jun 2022 8:44pm
KristoffL322
Been out in the car again today, and it's definitely making the noise at 1,000rpm. It’s doing it fairly consistently.
Post #635399 24th Jun 2022 6:50pm
Umiar
Did you check high presssure fuel pump? Sometimes after changing fuel filter this pump catches air and buzz in certain rpm
Post #635421 25th Jun 2022 6:11am
JayGee
It’s not a buzzing sound on mine. 2012 TDV8 Vogue (L322)
Post #635422 25th Jun 2022 6:41am
Umiar
Here is mine
Post #636018 4th Jul 2022 6:38am
JayGee
Doesn't sound like mine. I get a 'moan' noise just above 1krpm and then it goes as the revs go higher. 2012 TDV8 Vogue (L322)
Post #636026 4th Jul 2022 7:55am
Fox889
Sounds like the main fan to me……but as per norm, I’m probably wrong😳 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #636090 5th Jul 2022 6:18am
KristoffL322
Thats how mine sounds too. I'll take a video of it later this week and post it up.
Post #636106 5th Jul 2022 9:06am
kevinp
Can you guys replicate the noise revving the engine with the car stationary?
Post #636111 5th Jul 2022 12:15pm
Umiar
I will try today.
It changes or appears only when you move/add the throttle.
I know from the previous owner that recently my car had the fuel filter replaced.
Post #636115 5th Jul 2022 1:01pm
