![]() | Home > Technical (L322) > Resonance/groan when accelerating 2012 4.4 TDV8 |
Umiar Member Since: 21 Jun 2022 Location: Cracow Posts: 11 ![]() ![]() ![]() |
No strange noise when stationary. Maybe 10% of it but ta much higher revs, 2500-3000… |
In addition to a new AC compressor I had the fuel filter and brake fluid changed and the gearbox oil topped up ( small leak requiring further investigation) - can't hear the sound now. 2012 TDV8 Vogue (L322) |
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 130 ![]() ![]() ![]() |
Mine makes the "blowing across the top of a bottle noise" when air recirc is on.
KristoffL322 Member Since: 20 Jun 2022 Location: North West Posts: 27 ![]() ![]() ![]() |
Finally got an update on this. I've fixed the noise!
Takes me an hour to jack the car up as I'm so paranoid about being pancaked that I use three jacks and 4 axel stands.
Anyway, I can't have looked too hard last time as there was clearly a snapped bolt in the bellhousing/gearbox (not sure what you call it) metal shield thing. Looks like a previous spanner monkey had snapped it off and not bothered fixing it. I centre punched it and drilled it first with a cobalt bit, then stepped up one size with a left hand drill bit and it came out with no real drama and without damaging the threads. I made a replacement by grinding a bolt to a taper on the bench grinder and that was that. No more noise. Still haven't a clue about the oil leak, investigations continue on that front. But that noise was seriously annoying, so I'm glad its gone. Hardly a candidate for 'repair of the year' but I hate it when threads are not resolved, so I thought I'd post the solution to my problem.
Despite my earlier post saying the noise had gone I can confirm it didn't go. I noticed the other day when starting on a slope with the window down that the sound was accompanied by a metallic rattle / resonance so this may well be the cause on mine as well. 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Sort that oil leak. I’ll bet it’s the oil cooler in the V up top. Replace the cooler, gaskets and the 2 O rings. Loads of detail on here about it in Wiki. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Yes I suspect it is the oil cooler. I've ordered the gaskets and the viton o rings and will get it done when they arrive. The reason for getting the underside stripped down was to check that it wasn't the turbo return pipes, and they look ok, so oil cooler seems likely.
They were covering that up I have no doubt! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Just been under mine and the gearbox shield does rattle like a biscuit tin lid. I took it off but couldn't see anything wrong or where it was touching so put it back again and it seems to be silent now. Been driving around this afternoon with the window down and the familiar moan at very low revs is totally gone |
CharlieF322 Member Since: 19 Mar 2024 Location: Essex Posts: 16 ![]() ![]() ![]() |
Hell, did you get anywhere with the fuel pump after the fuel filter change comment? This is exactly what mine is doing after a fuel filter change. I’m assuming there is no air in the system as it starts and drives without mishap.
Anglo77 Member Since: 28 Feb 2024 Location: Huntington Posts: 9 ![]() ![]() ![]() |
Had this appear on my 2011 as well. Last thing I had done was a gearbox oil and filter change so suspected I had introduced it. I have checked the oil level several times, as in my head the sound sounded like a suction sound to me, but went away at high revs too. Maybe oil pressure related?
