Home > Maintenance & Mods (L322) > 150K miles coming up soon
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
Done already, new compressor and filter 👍🏻 Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #634930 18th Jun 2022 11:12am
Well I recon you must be about there then...
One thing to note if you have a tow bar, the lazy fitters remove a big grommet from the wheel well when they put the wiring through, well worth checking as a lot of water can get in on normal roads, let alone on the path least travelled...... Thumbs Up Pete
Post #634931 18th Jun 2022 11:20am
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
You seem to have it pretty much covered with your regular maintenance (some might say overkill, but who has ever caused a problem by changing oil frequently!).
You mention fluids, but does that include power steering fluids?
If you haven’t changed your plenum hoses, then maybe swapping them for some silicone ones? Fairly straight forward to do.
Maybe lanoguard the underside of the car as part of a clean and de-rust routine? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #634933 18th Jun 2022 12:00pm
Ffrr-lover
Re: 150K miles coming up soon
2010BlackL322 wrote:
Thinking fuel injectors, pulley bearings, and viscous fan bearings, they are noisy, water hoses
I swapped my pulleys and belts to get rid of noises (chirps!) and replaced my alternator, water pump and AC compressor (its solenoid was playing up - delayed cold) while i was there, and would agree with others that doing the lot while there is best (if costly) due to the hassle in getting the access you need!
Frustratingly, despite new (genuine) everything the chirping has started again when cold Big Cry I haven’t yet looked into what is making the noise yet. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #634934 18th Jun 2022 12:06pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Chirping could be the bearings on your blower motor …
Injectors ?
Wasn’t aware there was a maintenance regime for them
Post #634965 18th Jun 2022 7:04pm
He's got turbos, not a blower... Pete
Post #634966 18th Jun 2022 7:21pm
