![]() | Home > Maintenance & Mods (L322) > 150K miles coming up soon |
2010BlackL322 Member Since: 30 Oct 2021 Location: London Posts: 119 ![]() ![]() ![]() |
All,
Thanks, clearly don’t want to go silly, as I say, “ain’t broke” but the bearings at the front need doing, so.
Front aux belts, bearings and tensioner are a normal replacement / service item at higher miles. Don't delay if they are noisy. 2012 TDV8 Vogue (L322) |
I'd defo do the alternator then at that mileage. Had the water pump done on mine as it was leaking but not sure if it's a common fail but they are not too expensive. 2012 TDV8 Vogue (L322) |
Thanks, thinking the water pump as a matter of course, alternator, probably pushing it now at 150k Check out my YouTube channel
Kicking myself for not having mine done at the same time as belts and water pump…. 2012 TDV8 Vogue (L322) |
Good call, thanks |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1272 ![]() ![]() ![]() |
I've just done everything on the front of my engine mate, all pulleys, tensioner, water pump and while I was there the alternator as well.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Starter motor maybe too. They get a lot of abuse turning a 4.4L engine.
Gearbox has been flushed and new sump and filter. Agreed genuine all the way 👍🏻 Check out my YouTube channel
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Front seat filters...? Pete
Already replaced when I changed the fan motor over 👍🏻 Check out my YouTube channel
Vent on air suspension pump and change/dry the dryer medium...? Pete
