Home > Maintenance & Mods (L322) > Steering track rod end gaiters
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Hi
Started one job and have ended up looking at something else!
The track rod end gaiters on the steering appear to be leaking grease. Where can I get replacement gaiters and how bad is it to replace them? My RR is a 2011 4.4 VSE TDV8.
Anyone have any pics of how to change them??
Thanks in advance…..
Regards
Mark
Post #634438 12th Jun 2022 7:19pm
Phoenix
Do you mean the ball joints on the track rod end or the steering rack gaiters?
If the former, it's replacement track rod ends, if the latter, it's gaiters and proper clamps - cable ties won't do.
Post #634440 12th Jun 2022 7:24pm
Track ends removed from hub, then remove the trackrod end from the rack end, undo the gaiters and pop them off... it sound easy but rarely goes the way you want when it's jacked up on the drive...!! A motor factor should be able to get them, or the main dealer... Thumbs Up
You may have an internal leak and power steering fluid is getting pumped into the rack, check the fluid level before anything else... Pete
Post #634441 12th Jun 2022 7:26pm
nambFFRR
Sorry….wasn’t absolutely clear…..it’s the steering rake gaiters that are leaking….
Post #634442 12th Jun 2022 7:29pm
nambFFRR
I’ll check the fluid as suggested. Thanks for the tip
Post #634443 12th Jun 2022 7:30pm
