Home > Maintenance & Mods (L322) > Steering track rod end gaiters |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Do you mean the ball joints on the track rod end or the steering rack gaiters?
12th Jun 2022 6:24pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8274 |
Track ends removed from hub, then remove the trackrod end from the rack end, undo the gaiters and pop them off... it sound easy but rarely goes the way you want when it's jacked up on the drive...!! A motor factor should be able to get them, or the main dealer...
12th Jun 2022 6:26pm |
nambFFRR Member Since: 06 Aug 2018 Location: United Kingdom Posts: 191 |
Sorry….wasn’t absolutely clear…..it’s the steering rake gaiters that are leaking…. |
12th Jun 2022 6:29pm |
I’ll check the fluid as suggested. Thanks for the tip |
12th Jun 2022 6:30pm |
