![]() | Home > Maintenance & Mods (L322) > halo rings fitted to the 4.2 |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
Aaron have a look at ebay item number eBay Item No. 283395358888 120 mm x 36 they do say for sport but same for l322
strongstuff Member Since: 26 Jun 2019 Location: North Wales Posts: 44 ![]() ![]() ![]() |
Thanks for the link, much appreciated! 2008 L322 4.2 V8 SC Stornoway Grey
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Might be a bit trickier on my MY2011 as it already has the rings which I guess I would need to remove…? Christian.
Paddocks67 Member Since: 17 Apr 2020 Location: Glasgow Posts: 28 ![]() ![]() |
Hi l also have they halo lights fitted to my car,when they are on there are three lights that flicker on and off,so that I don't get full circle what could be causing that,and how would I fix it,thank pat |
hi pat i would say that some off the led chips have failed or are failing so i would say they may need replacing with new rings oggy new vehicle purchase
I was thinking maybe the wires where loose or something,I will wait until it gets worse before I start messing about with it thanks for the reply oggy,cheers pat |
