Home > Technical (L322) > Vibration at speed |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3206 |
Did this happen after. Fitting the new brakes? 2012 TDV8 Vogue (L322) |
11th Jun 2022 5:05am |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 |
No - these are all things I've done to try and eliminate it (needed doing anyway). 2011 4.4 TDV8 Vogue SE - 'Black Betty'
11th Jun 2022 6:18am |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Rear brake pistons/sliders. Handbrake shoes/system. |
11th Jun 2022 7:02am |
Do you get any sense if it's front or rear? Is there vibration through the steering wheel? Even with a full wheel balance and new tyres (what tyres BTW) you can still get dynamic inbalances from other parts of the rotating mass like the disks and there are wheel balancing systems that will test the wheel on the car such as Hunter road force systems. Also driveshafts and CV joints ( inner and outer) can be culprits for vibration. 2012 TDV8 Vogue (L322) |
11th Jun 2022 9:52am |
I think it's coming from the rear.
11th Jun 2022 9:55am |
Any imbalance at the front would be felt through the steering wheel so for the moment rule that area out. I'd rotate the wheels one at a time from the front to the rear and test but if this was present before the tyre change it's not an obvious fix. When I recently changed my rear disks I noticed that they were balanced (LR genuine / Brembo) I could see how an unbalanced disk of this size and rotating mass could cause vibration. 2012 TDV8 Vogue (L322) |
11th Jun 2022 10:03am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
if the center bearing is fine have the UJ looked at and check the rubber doughnut for signs of wear. 2012 Vogue 4.4 TDV8 - Current
11th Jun 2022 10:34am |
Think the NSR caliper is binding. Disc is roasting hot, can't touch it yet OSR is relatively cool in comparison. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
11th Jun 2022 11:43am |
11th Jun 2022 12:59pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8202 |
It's a common issue... if you fancy doing it yourself, some pointers...
Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
11th Jun 2022 1:48pm |
I’d have rebuilt mine but wanted to minimise time off the road so went with new (recon?) callipers. If you go for rebuilding and don’t have a high pressure air system pull the inner pad and use the brake to push out the piston before you take the calliper off. I got mine out with pipe grips and a vice but it was very hard work. 2012 TDV8 Vogue (L322) |
11th Jun 2022 2:18pm |
To be honest, ordinarily I'd be all over this doing it myself but because these days I simply cannot be arsed, it'll go back in to the garage to be done. What's another few hundred quid when you've already put about 3k in to it over the past 6 weeks? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
11th Jun 2022 2:23pm |
Genuine LR disks (Brembo), Delphi pads and recon callipers cost me £550. 2012 TDV8 Vogue (L322) |
11th Jun 2022 4:12pm |
