Home > Technical (L322) > P132E fault code .new turbo fitted twice and still baffeld.
Croker
Spain
So we are really running out of ideas now...This is what has happened so far:
initial problem: LH turbo failure (no warning lights of codes logged which was weird) Inlet side vanes mashed and twisted and whole turbine seized. Happened under full power up hill. 118,000 miles.
1st course of action: Replace both turbos with reconditioned units from Turbos24h (spanish company as I am based in spain)
Result: Upon start up, Engine running fine with no codes until throttle blipped then Engine fault code P132e. Code cleared and vehicle test driven. There was fluctuating boost levels on the left turbo. RH turbo no problem. After 20 km test at various power and load the fault code is back.
2nd course of action: Remove LH turbo to find damaged vane edges. Turbo returned to supplier to be told in their opinion it was matter damage caused from debris in the intake pipe (BS in our opinion, we believed it was overspeeding damage but we cannot be sure). Repaired turbo, test sheet and bench test video received with the second unit. Refitted second turbo. Upon start up no error until the throttle is blipped then P132e is back again!
Diagnostics show reduced flow on LH MAF while running. Actuators are functioning on the diagnostics self test. Both LH and RH actuators move freely as they are clean, rust free condition.
Continuity on all cables from ECU socket to Actuator socket.(no broken wires or pins).
So, we are not going to test drive again until we have a reason for the P132e code. We are going to inspect the vanes in the LH turbo tomorrow with an endoscope to check there is no damage to the vanes.
Has ANYONE got a solucion to the P132e error code taking into consideration all that has been check so far? Could there be an electrical fault with the actuator causing the code even though they are cycling correctly? Any other possible issues that we haven't found? All the usual checks have been done such as split hoses, cracked inlet manifolds or bad wiring.
Thanks in advance....
Post #618590 3rd Jan 2022 7:46pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Sorry, are we talking the 3.6 or 4.4 diesel? 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #618591 3rd Jan 2022 7:54pm
GraemeS
Australia
Is the code P132E21 (left) or P132E22 (right)?
Have the left and right MAF and MAPT sensors been swapped (1 at a time) to check that the code doesn't swap sides?
Post #618601 3rd Jan 2022 9:09pm
Croker
Spain
Sorry! 3.6 TDV8 2007
Post #618614 3rd Jan 2022 10:59pm
Croker
Spain
Yes swapped MAF and still same error P132E Turbo/Supercharger Boost Control B Performance
Also swapped the pressure sensors after the throttle bodies.
Post #618615 3rd Jan 2022 11:02pm
Croker
Spain
This is the air flow reading we get by manually operating the LH actuator whilst at idle.
https://youtu.be/ApAnB-Yb1yA TDV8 3.6 2007 Vogue SE
Porsche Boxster 3.2S 2000
Porsche 928S 1986.5 Manual
Fiat Dino 2000 Coupe
BMW 2002 tii 1974
Mercedes 450SL 1973
Mercedes SL500 1995
Honda Civic 1.8 Si 2006
Fantic Caballero 125 Scrambler Deluxe
Post #618648 4th Jan 2022 11:16am
Treebor99
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
First I'm going to say I have no experience with the 3.6 and it's Turbos.
However
I do know turbo's can be damaged by over-speeding - which you suspect happened to the new Turbo.
A very common cause for over speeding turbos is a boost leak.
have you checked and double checked all the joints, hoses, connections, pipes, intake manifolds, for splits and leaks?
It could be the code you are getting is related to incorrect boost pressure versus air flow??? (I'm guessing a bit now but that's something I'd be checking).
I wish you all the luck in the world and hope you find the solution quickly without too much expense. Anything can be made to work if you fiddle with it long enough (and have deep pockets|)
Current cars, 2011 FF 4.4 TVD8; Audit TT 1.8T convertible.
Post #618652 4th Jan 2022 11:58am
GraemeS
Australia
Are you seeing the full code - P132E21 or P132E22 which identifies which turbo?
Is sounds as though you have the workshop manual but in case not then here's the action for the DTC.
Check the turbocharger and circuits. Refer to the
electrical guides. Using a datalogger function, record the
turbocharger actuator angle at idle and at 3,000 rpm.
From idle, "blip" the throttle to maximum and allow to
idle and record the turbocharger actuator angles. At idle,
the angle should be approximately 95%, at 3,000 rpm,
approximately 40%, and when "blipped" the voltage
should change smoothly at approximately 25% per 100
ms. If the voltages do not change or do not change at the
expected rate, suspect the turbocharger actuator is
sticking. Install a new turbocharger.
Post #618654 4th Jan 2022 12:19pm
Xpand1t
United Kingdom 2010 Range Rover SE TDV8 Zambezi Silver
Hi I have the same problem with a rr sport tdv8 3.6 did you ever diagnose the problem as we are pulling our hair out
cheers
Post #633554 2nd Jun 2022 8:07pm
Croker
Spain
Yes I did! And the same issue was on another RR Sport here in spain and we resolved that too...Both cases it was the left turbo that had been REBUILT albeit by different suppliers. The problem was the Actuator arm was fitted 180 degrees out!! TDV8 3.6 2007 Vogue SE
BMW 2002 tii 1974
Mercedes 450SL 1973
Mercedes SL500 1995
Post #633555 2nd Jun 2022 8:13pm
Xpand1t
thanks for letting me know
Post #633557 2nd Jun 2022 8:26pm
Xpand1t
Sorry to be a pain but how did they resolve this, by simple rotating the actuator arm or electronically.
did the turbo need to be removed and or did you send it back to the rebuilder.
Do appreciate the info as i’m sure other members will to.
Post #633592 3rd Jun 2022 8:45am
Croker
Spain
I am taking the company to court. They supplied the 2 new turbos which is when we realised the error they had made in the rebuild. I also sent the erroneos turbo for an independent test by Borg Warner agents and they reported back it was faulty and the flow rate was down by approx 20% and out of parameters. So, Im now waiting for the court case to reclaim all costs. The way to fix it would be refit the actuator arm in its correct position and calibrate correctly. TDV8 3.6 2007 Vogue SE
BMW 2002 tii 1974
Mercedes 450SL 1973
Mercedes SL500 1995
Post #633659 4th Jun 2022 2:24am
Riad 55
Spain 2007 Range Rover HSE TDV8 Giverny Green
Hello
have you found the solution please?
I have exactly the same problem and have been completely lost for 2 months now. Thank you very much
Post #684656 3rd Feb 2024 10:25am
Croker
Spain
I fitted 2 brand new Original turbos but after a breif period of functioning the problem was back but I found a shorting out of a cable on the plug to the LH actuator which occured upon the first revving of the engine after resetting the fault code. A tiny spark jumped from one of the 5 cables in the plug to the housing! Replaced the section of wiring and plug and cured it! I then had even with brand new turbos a sticking actuator arm on the RH side turbo a couple of times but with some wd40 I freed it up and all good. TDV8 3.6 2007 Vogue SE
BMW 2002 tii 1974
Mercedes 450SL 1973
Mercedes SL500 1995
Post #684677 3rd Feb 2024 4:40pm
