Home > Technical (L322) > P132E fault code .new turbo fitted twice and still baffeld. |
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 404 |
Sorry, are we talking the 3.6 or 4.4 diesel? 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
3rd Jan 2022 6:54pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2515 |
Is the code P132E21 (left) or P132E22 (right)?
3rd Jan 2022 8:09pm |
Croker Member Since: 23 Mar 2021 Location: Granada Posts: 33 |
Sorry! 3.6 TDV8 2007 |
3rd Jan 2022 9:59pm |
Yes swapped MAF and still same error P132E Turbo/Supercharger Boost Control B Performance Also swapped the pressure sensors after the throttle bodies. |
3rd Jan 2022 10:02pm |
This is the air flow reading we get by manually operating the LH actuator whilst at idle.
4th Jan 2022 10:16am |
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 |
First I'm going to say I have no experience with the 3.6 and it's Turbos.
4th Jan 2022 10:58am |
Are you seeing the full code - P132E21 or P132E22 which identifies which turbo?
4th Jan 2022 11:19am |
Xpand1t Member Since: 02 Jun 2022 Location: kent Posts: 3 |
Hi I have the same problem with a rr sport tdv8 3.6 did you ever diagnose the problem as we are pulling our hair out
2nd Jun 2022 7:07pm |
Yes I did! And the same issue was on another RR Sport here in spain and we resolved that too...Both cases it was the left turbo that had been REBUILT albeit by different suppliers. The problem was the Actuator arm was fitted 180 degrees out!! TDV8 3.6 2007 Vogue SE
2nd Jun 2022 7:13pm |
thanks for letting me know |
2nd Jun 2022 7:26pm |
Sorry to be a pain but how did they resolve this, by simple rotating the actuator arm or electronically.
3rd Jun 2022 7:45am |
I am taking the company to court. They supplied the 2 new turbos which is when we realised the error they had made in the rebuild. I also sent the erroneos turbo for an independent test by Borg Warner agents and they reported back it was faulty and the flow rate was down by approx 20% and out of parameters. So, Im now waiting for the court case to reclaim all costs. The way to fix it would be refit the actuator arm in its correct position and calibrate correctly. TDV8 3.6 2007 Vogue SE
4th Jun 2022 1:24am |
Riad 55 Member Since: 03 Feb 2024 Location: Benidorm Posts: 1 |
Hello
3rd Feb 2024 9:25am |
I fitted 2 brand new Original turbos but after a breif period of functioning the problem was back but I found a shorting out of a cable on the plug to the LH actuator which occured upon the first revving of the engine after resetting the fault code. A tiny spark jumped from one of the 5 cables in the plug to the housing! Replaced the section of wiring and plug and cured it! I then had even with brand new turbos a sticking actuator arm on the RH side turbo a couple of times but with some wd40 I freed it up and all good. TDV8 3.6 2007 Vogue SE
3rd Feb 2024 3:40pm |
