Home > Technical (L322) > Key won't turn in ignition
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Alternatively you can consider an emulator, which works beautifully, costs less than a used column and is a 5 minutes fit.
I had the lock repaired, only to get stuck again and repaired once more by the same garage.
I decided to plug the emulator and move on, thus sparing the old lock. Steering wheel of course doesn't lock but I don't care about the function and I can always switch back to standard but I don't think I'll ever want to...
Post #632503 22nd May 2022 3:51am
RobL322
Thanks for the advice. Does the emulator remain fitted?
Can see used part from £90 - £250 on Ebay in UK.
The emulator price is in that range.
Post #632511 22nd May 2022 8:44am
vs322
Yes, the emulator remains plugged in lieu of the steering lock ECU.
The emulator cost me 40 € + 30 € Shipping and dues.
Post #632512 22nd May 2022 8:49am
RobL322
My car is working as intended now after fitting an *emulator. Have read all the advice here and other places, plus watched many videos. Happy with this solution *because* mine failed int he open position. There is no electrical connection to my steering lock so pretty confident it cannot lock. For certain it was not locking when electrically connected and drive by an ECU.
The only proper fix is fitting a new part with a guarantee. Anything else is compromise at best and bodge at worst. My own car is worth less that a new column / locking unit so chose the "least worst" option. Any second hand unit might be only days away from failing itself so not worth the time and money in my book.
* emulator Like ^^. about €40 + €30 shipping. Slightly nervous that delivery took 9 days after DHL.de reported the item was collected. Maybe the UK customs system was the bigger factor here.
Post #657955 27th Feb 2023 9:44am
vs322
Great news! Glad everything is in order. I'm still running mine on the same emulator with no intention of switching back to the original configuration. Thumbs Up
Post #657957 27th Feb 2023 10:04am
robanzac
New Zealand
This is interesting and something that I have only learned of today.
I haven't a problem yet, but it may well happen.
Can you point to the emulator to buy ? Rob
Post #667647 26th Jun 2023 7:40pm
vs322
They seem to have updated the plastic shell...plug should fit more securely now. Not that there is any issue with the older one but this looks tidier
https://goldcar.com.tr/product/for-range-r...-emulator/
As pointed out on their site, if the lock is (or has failed in) the unlocked position, all you need to do is unplug the ecu and plug the emulator. If the lock has failed in the locked position, you will have to dismantle the locking mechanism. Not sure if the upper column has to be off the car as they say but would probably be easier to work on.
Post #667673 27th Jun 2023 3:08am
robanzac
New Zealand
Thanks - I will order one.
I take it that you need to make sure that the lock is in the "unlocked position" at the time that the loom is disconnected from it.
So , for an installation to a working mechanism, the ignition key needs to be inserted to do this job.
Then you can connect the emulator Rob
Post #667675 27th Jun 2023 5:53am
vs322
You are correct, sir. You just unplug the steering lock ECU with the key in ignition. Thumbs Up
If you don't really care for a locking steering wheel as a security feature (I don't) just go ahead and install the emulator anyway. This way you preserve a working lock and spare yourself any possible inconvenience or headache down the road.
Post #667677 27th Jun 2023 6:13am
Jojo
Spain
Hi to everyone!
One question vs322, the emulator works on 2007 RR, the one with the key on the dashboard not the console? Do you know?
Thanks!!
Jojo.
Post #670306 2nd Aug 2023 11:46am
vs322
I'm almost certain it does. You can confirm with goldcar to be sure.
Post #670307 2nd Aug 2023 11:54am
