![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 ![]() ![]() ![]() |
So I think it should be current (A) rather than volts, maybe the iCarsoft is just labelling this incorrectly. Also the stiffness value (Nm) will be a calculated value from the current demand (basically just reading off a scale), so it won't be reporting real-time stiffness data unfortunately. Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw Home of the 'Cheapest 4.4 TDV8 Range Rover" |
I think they energize once you start moving, rather than just engaging drive - but could be wrong there, been a while since I had it plugged into SDD. Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 731 ![]() ![]() |
Not trying to detract from the core issue in this thread but I'm feeling my steering is heavier than it should be lately.
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Mine just fine! Sweet, in fact... Some of those over-priced tyres can make it seem heavier, for some reason, though who knows why?!? Maybe to make them wear out faster?!? |
Mine feels fine, not finger-tip light but nearly. That's even with my big A/T tyres on. I seem to remember a problem that the early L322s had with their 'servotronic' valves for the steering - which is meant to vary steering weight according to speed. I'd be surprised if it's related to the harsh ride, but I won't say it's impossible! Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw Home of the 'Cheapest 4.4 TDV8 Range Rover" |
Thanks for your input guys!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
My steering is fine… light at slow speeds, bit heavier as speed builds, though to be fair, it normally has a belly resting on it, so self centering not the best 🤣.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
according to live data as soon as you go into drive, voltage goes to 1.5 and nm goes to 250NM this is for the rears will check the fronts 2012 Vogue 4.4 TDV8 - Current 2014 Navara V6 - Gone 2004 Vogue TD6 - Gone Grand Cherokee - Gone Discovery V8 (LPG) - Gone Discovery TD5 - Gone |
Reidsr Member Since: 31 Dec 2021 Location: Aberdeen Posts: 10 ![]() ![]() ![]() |
After Sam has changed his front struts and found no change I'm now thinking it must be bush related. I have had the bushes checked but i think they have just done the quick test that MOT require for suspension bushes not for subframe mounts. It feels as though my whole subframe is loose and moving about! But no clunking which might counteracts the claim. Im fed up of how it drives. |
has Sam changed them then? cannot see a video have i missed something 2012 Vogue 4.4 TDV8 - Current
Not recently, though Sam said in a video that he had put non CVD units on, and it was pretty much the same.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Correct. We are all waiting with anticipation to prove the theory correct |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Me too… although I am delayed due to needing new control arms too. I have a £1,700 bill for all those parts if I include the struts too. |
UPDATE
