Home > Maintenance & Mods (L322) > halo rings fitted to the 4.2 |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
Much better than the fairy lights, how difficult was it getting the headlight apart? Christian.
17th May 2022 5:17pm |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 640 |
Oggy you beat me to it, that's what i was going to do to my headlights. I've got the rings already and was going to spray the surrounds gloss black, but it didn't work out with the chrome lifting when taking the masking tape off. Now I've seen yours, I'm certainly going to do mine when i get chance.
17th May 2022 6:04pm |
I've got a 2011 model so my headlights are a little different, is 120mm the right size for all headlights? Christian.
17th May 2022 6:27pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
hi caesium the lense was very easy to remove . you have to heat it up well with a heat gun cut some 3 wood wedges when hot go into the edge with a plastic trim tool and twist when open cut the butyl sealer close to the edge of the lense with a stanley knife and put a wedge in and go around start from the area that is close to the front grill first . just remember to take the torx screws out ref the indicator unit which goes in to the front lense . and when you wire the halos just remember the the black wire number 2 in the pins is the live wire and pin 1 is the red is the earth that is if you pick up the live and earth from the side light wires which i did so they would run on side lights day running colours are which is the reverse of what we know
17th May 2022 6:28pm |
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 |
They look great Oggy.
17th May 2022 6:37pm |
hi barmybrummie yes i did no you wear going to have a go at it is just that the chrome is bad news so i did not spray mine you cant mask up that inner lense . i left mine because i have a lot of carbon fiber sheet on my still would like the side light bulb holder thanks oggy new vehicle purchase 2007 supercharged 4.2 java black .sand leather vogue se trim previous cars . range rover classic 200 tdi discovery 1 200 tdi freelander 2 2008 hse discovery 1 300 tdi p38 4.0 ltr man r380 ex royal support vehicle on v5c discovery td5 man off roader |
17th May 2022 6:39pm |
Pm sent oggy. |
17th May 2022 6:44pm |
hi yes of course ref pictures it is back in the workshop doing stuff that i never got to do when i got it so on going for a couple of weeks yet new vehicle purchase
17th May 2022 6:45pm |
hi caesium i am not sure ref the size for yours but i am sure we can find out for you i will have a look on some web sites oggy new vehicle purchase
17th May 2022 7:12pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 499 |
Oggy,
17th May 2022 7:35pm |
thank you peter for your comments . they are not to bad to do just to take your time and make sure you have everything ready and you have all the bits to do it all hear to help if you have a go just ask any time thanks oggy new vehicle purchase
17th May 2022 8:01pm |
strongstuff Member Since: 26 Jun 2019 Location: North Wales Posts: 44 |
That looks great, nice work!
17th May 2022 10:56pm |
hi Aaron i got this set from ebay around £50 . when the lights go back in place i use a very thin line of pu black tiger seal in the back part of the light dont put it on the lense when you put it back together push down as far as you can then heat it up again it will go flush and then start to put the 6 clips back they will pull it back in place and the 2 screws will pull lense in as well put the edge of the clips on lense first and push down they will click in place new vehicle purchase
18th May 2022 1:36pm |
Brilliant, thank you.
18th May 2022 1:58pm |
