Home > Maintenance & Mods (L322) > halo rings fitted to the 4.2
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
fitted the halo rings started yesterday and fin to day went for the 120 mm x 39 leds staggad . not to bad to do all solder joints then heat shrink just remember black is live and red is earth bin in motor trade 40 years and never had black as live that was a bit trying never mind all done on to the next job
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #631999 17th May 2022 4:15pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Much better than the fairy lights, how difficult was it getting the headlight apart? Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #632000 17th May 2022 4:17pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Oggy you beat me to it, that's what i was going to do to my headlights. I've got the rings already and was going to spray the surrounds gloss black, but it didn't work out with the chrome lifting when taking the masking tape off. Now I've seen yours, I'm certainly going to do mine when i get chance.
Caesium it's very easy to split lights. Remove clips around headlight lens and then i used a heat gun on on a number 1 setting medium heat to soften the glue and just gently prise the lens from the unit. 20 mins each light. Hope this helps.
Post #632003 17th May 2022 5:04pm
Caesium
I've got a 2011 model so my headlights are a little different, is 120mm the right size for all headlights? Christian.
Current Cars
2019 BMW X4
or
Post #632006 17th May 2022 5:27pm
oggy
hi caesium the lense was very easy to remove . you have to heat it up well with a heat gun cut some 3 wood wedges when hot go into the edge with a plastic trim tool and twist when open cut the butyl sealer close to the edge of the lense with a stanley knife and put a wedge in and go around start from the area that is close to the front grill first . just remember to take the torx screws out ref the indicator unit which goes in to the front lense . and when you wire the halos just remember the the black wire number 2 in the pins is the live wire and pin 1 is the red is the earth that is if you pick up the live and earth from the side light wires which i did so they would run on side lights day running colours are which is the reverse of what we know
just a note do not touch the chrome part of the inner lense as it will come off if you just look at it just wipe it with a clean cloth new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #632007 17th May 2022 5:28pm
Seriouslthinkingaboutit
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
They look great Oggy.
Can you do a daylight picture with them on as DRLs
Thanks
Douglas 2007 4.2SC Buckingham Blue
https://www.fullfatrr.com/forum/topic63319.html
Post #632010 17th May 2022 5:37pm
oggy
hi barmybrummie yes i did no you wear going to have a go at it is just that the chrome is bad news so i did not spray mine you cant mask up that inner lense . i left mine because i have a lot of carbon fiber sheet on my still would like the side light bulb holder thanks oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #632012 17th May 2022 5:39pm
Barmybrummie
Pm sent oggy.
Post #632015 17th May 2022 5:44pm
oggy
hi yes of course ref pictures it is back in the workshop doing stuff that i never got to do when i got it so on going for a couple of weeks yet new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #632016 17th May 2022 5:45pm
oggy
hi caesium i am not sure ref the size for yours but i am sure we can find out for you i will have a look on some web sites oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #632025 17th May 2022 6:12pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Oggy,
All I can say is wowww! it really upgrades the appearance of the front lights.
Im not brave enough to attempt it especially seeing the replacement cost of a unit.
10/10 ++
Peter
Post #632027 17th May 2022 6:35pm
oggy
thank you peter for your comments . they are not to bad to do just to take your time and make sure you have everything ready and you have all the bits to do it all hear to help if you have a go just ask any time thanks oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #632031 17th May 2022 7:01pm
strongstuff
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
That looks great, nice work!
2 questions if you don't mind ...
Where did you buy the halo rings from?
How do you stick the lens back on when you've done the halos?
Thanks!
Aaron 2008 L322 4.2 V8 SC Stornoway Grey
2006 L322 4.2 V8 SC Java Black
Post #632048 17th May 2022 9:56pm
oggy
hi Aaron i got this set from ebay around £50 . when the lights go back in place i use a very thin line of pu black tiger seal in the back part of the light dont put it on the lense when you put it back together push down as far as you can then heat it up again it will go flush and then start to put the 6 clips back they will pull it back in place and the 2 screws will pull lense in as well put the edge of the clips on lense first and push down they will click in place new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #632115 18th May 2022 12:36pm
strongstuff
Brilliant, thank you.
Off to eBay I go ... Whistle 2008 L322 4.2 V8 SC Stornoway Grey
Post #632119 18th May 2022 12:58pm
