![]() | Home > Technical (L322) > [Fixed] New noise from the engine… high pressure fuel pump |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Hi everyone!
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 779 ![]() ![]() ![]() |
Turn the heater fan on when you hear the noise, see what happens...... I recall once having a scary noise which turned out to be something in the fan. The older I get, the more I realise that people confuse wrinkles for wisdom |
Cheers JMC
So today I spent some time investing this noise and have found the source.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
Is the fuel filter overdue for a change? |
Possibly. I don’t know when last changed. I did order a new one for its last service, but was sent the wrong one. Am just sorting out its replacement.
Interesting.
Keep in mind the issue with the connector wiring to the fuel pressure sensor although that reportedly results in fuel pressure too low causing the engine to stall while idling rather than excessive pressure that could cause a vibration. |
Cheers Graeme
A replacement harness section is used to fit a new connector. LTB01083. |
The new fuel filter finally arrived… except it was rattling!
Pretty Member Since: 09 May 2022 Location: Hampshire Posts: 1 ![]() ![]() ![]() |
Hello . I just wanted to check if you sorted this as my 2012 4.4 tdv8 is doing the same. The car broke down, fitted a new fuel filter, bled some air out and managed to start her but now high pitch resonance coming from return pipes i think from hpfp. I think its air in the system still . How did you get on ? Thanks graham |
I finally received a new filter a few days ago, and swapped them last night.
This is where the noise was emanating from for me…
This photo was taken stood by the passenger side wheel. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
