Home > Technical (L322) > [Fixed] New noise from the engine… high pressure fuel pump
Page 3 of 3 <123
AlexLRV8
United Kingdom 2008 Range Rover Vogue TDV8 Zambezi Silver
On the 3.6 tdv8 the fuel injectors can cause vibration/humming noises, often accompanied by less than perfect gear shifts. Can you check injector values on IID like on the 3.6?
Post #692033 6th May 2024 11:09pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I have now managed to fix the noisy High Pressure Fuel Pump!!!
Well, I say I did... by that I mean I passed a few notes with the kings face on it to someone else who did the hard work!
The issue, in my case at least, was the fuel sender in the fuel tank was no longer working! I am surprised that the car started at all, however there clearly is enough of a draw elsewhere!
In my case the fuel pump was actually fine, it was a dodgy connector that had burned out and needed to be replaced.
All in, about £450 for a few hours labour, a replacement something or other, and an oil change too whilst it was in the garage.
And now I can put my foot down without fear of that noise starting up and staying there continuously for the rest of the journey! oh the joy of a 2 1/2 tonne vehicle accelerating surprisingly quickly!!! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #694941 23rd Jun 2024 11:46am
Astanavits
France
Hello, is the noise of your pump similar to that of mine?
https://youtube.com/shorts/x1vBup9Neyg?si=U0CKZqD196xkX06w
Post #712103 18th Feb 2025 3:30am
Page 3 of 3 <123
