Home > Technical (L322) > [Fixed] New noise from the engine… high pressure fuel pump |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Hi everyone!
5th Apr 2022 3:37pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Turn the heater fan on when you hear the noise, see what happens...... I recall once having a scary noise which turned out to be something in the fan. The older I get, the more I realise that people confuse wrinkles for wisdom |
5th Apr 2022 3:56pm |
Cheers JMC
5th Apr 2022 5:20pm |
So today I spent some time investing this noise and have found the source.
9th Apr 2022 11:27am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2470 |
Is the fuel filter overdue for a change? |
9th Apr 2022 12:19pm |
Possibly. I don’t know when last changed. I did order a new one for its last service, but was sent the wrong one. Am just sorting out its replacement.
9th Apr 2022 2:02pm |
Interesting.
9th Apr 2022 2:22pm |
Keep in mind the issue with the connector wiring to the fuel pressure sensor although that reportedly results in fuel pressure too low causing the engine to stall while idling rather than excessive pressure that could cause a vibration. |
9th Apr 2022 8:40pm |
Cheers Graeme
10th Apr 2022 7:43am |
A replacement harness section is used to fit a new connector. LTB01083. |
10th Apr 2022 12:07pm |
The new fuel filter finally arrived… except it was rattling!
22nd Apr 2022 12:35pm |
Pretty Member Since: 09 May 2022 Location: Hampshire Posts: 1 |
Hello . I just wanted to check if you sorted this as my 2012 4.4 tdv8 is doing the same. The car broke down, fitted a new fuel filter, bled some air out and managed to start her but now high pitch resonance coming from return pipes i think from hpfp. I think its air in the system still . How did you get on ? Thanks graham |
12th May 2022 1:27pm |
I finally received a new filter a few days ago, and swapped them last night.
12th May 2022 6:11pm |
This is where the noise was emanating from for me…
12th May 2022 6:41pm |
