Home > Technical (L322) > Any tips on replacing coolant water pump
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
So as explained in my other threads I think my water coolant pump needs replacing due to the DTC's I'm getting. Is this a fairly simple thing to do. LR has stock so can have one tomorrow for £120 which aint that bad so I was thinking of doing it myself. Dont think I need to replace anything else at the same time as nothing else is mentioned in the technical bulletin. My rave doesn't contain SC info so I'm abit unsure. I think as long as I have diagrams and info I will be fine. Anybody had experience of doing this or any tips for me.
cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #63105 9th May 2011 10:48am
Not sure on the SC but make sure you get a new joint/gasket. May come with the new pump but might be a separate order part.
Post #63108 9th May 2011 11:27am
Ludzy
Don't think I need one. It's the auxiliary water pump (sorry forgot to point that out) doesn't mention any kind of gasket in the microcat.
Cheers Ex FFRR 4.2 Supercharged
Post #63109 9th May 2011 11:35am
Ah sorry thought you ment the main cooling water pump.
Post #63112 9th May 2011 12:25pm
dan_uk_1984
The aux coolant pump is in the same locale for all models.
Have you verified it's not running by turning the ign on and the heater on max temp with fan speed low, then put your hand on the pump, it will either be vibrating or not. Not means its dead.
This happened on mine, and also Neo's RR so seems to be an increasingly common failure item (much like it is on the BMW's it's come off of)
It uses BMW push fit connectors so is relatively strait forward to swap out - however it is in a hard to reach place so get a milk crate to stand on.
I paid £90 inc parts & labour to replace.
http://www.fullfatrr.com/forum/topic4129.html
Post #63136 9th May 2011 3:55pm
Ludzy
No problem. Looks fairly simple swap out. Unclip the 2 hoses and the electric cable and that's it. Think the hardest thing will be swapping the cable connecters the right position.
Post #63139 9th May 2011 3:57pm
Ludzy
The pump may not actually be broken. It's advised that it gets changed when changing the cross connections which is causing my reduced engine performance msg. Ex FFRR 4.2 Supercharged
Post #63142 9th May 2011 4:04pm
dan_uk_1984
I'm not familiar with the SC engine, can you explain what you mean by cross connections? I've heard of the cross over valves in the heating/cooling system... is it those?
D
Post #63145 9th May 2011 4:12pm
Ludzy
D
The auxiliary pump may be have been cross connected in connector C3006 + & - the wrong way round. This causes the pump to run backwards over time which eventually will throw up the P2601 codes I have been getting causing my SC to get the reduced engine performance msg. Theres a technical bulletin from 2007 that covers it. My SC's Vin matches the ones that are affected. So I'm hoping it's this. Just a case of swapping over the cables but as a extra measure it's best to change the pump at the same time. Seems to be a lot about this problem with the SC engines on google. Hopefully this with cure my problem if not then it's back to the drawing board.
Post #63172 9th May 2011 5:20pm
dan_uk_1984
Ah I see - good ole Land Rover, not knowing what the hell they are doing!
Post #63174 9th May 2011 5:25pm
Ludzy
Well fitted the new coolant pump this afternoon. Seemed to take bloody ages getting the hoses off! The red/white & brown cables to the pump were as aspected the wrong way round so rather than pull them out the connecter I just trimmed the little plastic stopper on the new pump and plugged the connector back in the other way round, saved loads of hassle pulling cables out and re-wiring them back in. The only problem I had was that the bolt thats holds the pump clamp to the car snapped so I had to secure the clamp with cable ties. Anyway job done. Took it out for a good 40 mile run with most of that under very heavy load Wink
No sign of any problems and more importantly no reduced power msg. So Hopefully thats all sorted?
A bit off topic but I also managed to get it into super extended mode when I drove over some grass onto my drive. I've been trying to get it into that for ages Smile
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Ex FFRR 4.2 Supercharged
Post #63302 10th May 2011 4:38pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Did you have any problems bleeding the coolant system afterwards ? I had a few issues getting mine bled properly.....
Post #63303 10th May 2011 4:42pm
Ludzy
No not really. Just took the coolant tank cap off then loosened the bleed screw just above the pump until coolant came out with no air bubbles. Ran the engine for 30 secs then did again but no bubbles this time. Gonna let the engine cool down then top up if needed.
Post #63306 10th May 2011 5:21pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
...good stuff... Thumbs Up 2004 black Vogue TD6
Post #63308 10th May 2011 6:05pm
Ludzy
Cheers mate. Thanks again for ya info on the obd stuff.
Thumbs Up Ex FFRR 4.2 Supercharged
Post #63326 10th May 2011 8:03pm
